Posted by Steamer1915 on 27/02/2014 06:50:31:
I believe that there is an analogy with using a Myford lathe with or without a gearbox. Whilst it is perfectly acceptable to use a changewheel model, once the gearbox option is taken, the user will wonder how they ever managed without it.
I strongly disagree with that statement having been there.
When I had my ML7 I lusted after a gearbox for years, cursing every time I had to swap gears which was often.
Eventually I found a S/H box and fitted it, then bought the very expensive Myford Metric conversion kit and realised I had made the biggest mistake of my life.
Before what was a two minute job swapping gears, then became a ten minute job swapping gears and banjo only to have to swap back to get the fine feed back. I really cursed the day I fitted it.
It was only later I discovered the 33 / 34 gear trick that Brian Wood has recently wrote up in MEW that makes life a lot easier.
It's obviously that popular that Brian says RDG sold out in one day and I'm currently making another batch of 200 gears.
