HI, all.
Today I stripped my small mill (CMD10) table down and tuned it up a bit. I'm pleased with the result, but I wonder if I can do a bit better.
The lead screw is effectively held firm by the handwheels which turn it. there is a locking nut which screws down and presses the handwheel against the mount.
I discovered that one of the reasons I had silly backlash on the cross table (X?) was that I'd not tightened it down hard enough.
The problem I'm seeing is that the resistance to turning is not even through the 360 degrees of the wheel. half turns well and half binds. If I tighten it up then it is hard to turn, but there is little movement or backlash. If I loosen it, the wheel is easy to turn but the backlash is more significant.
I had in mind to see if I could some thrust bearings and interpose between the wheel and the mount (or possibly the lead screw and the mount on the other side. I could thus tighten the wheel down a bit more but still have reasonably free turning.
Of course this is just hiding the ultimate root of the problem, but I'm not sure I'm up to discovering that and fixing it. It is a relatively small backlash and about as good as the mill has been since I got it.
Is this a sensible thing to do or should I be satisfied with what I've got?
Iain
