Hi guys,
Just looked in on this topic and thought I would contribute again.
The only problem I have with the metric system is when some nitwit implies that I must use it . As others have said, what I do in the privacy of my own shop is entirely my business and no one else’s. I could machine a square block to the same size as someone else by using Imp when theirs was made using metric, as long as the conversion is widely, and it is, known. It really does not matter a jot.
Would the metric wallahs whinge at Cherry Hill’s (or any DOE award winner) work if it was known she or they had used Imp units, of course not, it is the end result that matters, not how you got there. An inch is 25.4mm is an inch etc. Come to think of it I am wrong an inch is 0.0254M as mm are not the preferred units in SI. Or have I got the decimal point in the wrong place? That is the trouble with decimal, each point place puts you out by a factor of ten. This is something the IMP system is more immune from than the other, but I digress.
If I had an Imp lathe I would not change it to a metric one till it was thoroughly worn out, I would consider a DRO, which makes the thought of change even less relevant as you can switch from one to t’other at will. I admit to using metric tooling and screw fittings because they are cheaper and easier to get than Imp, not because of any perceived benefits (which are dubious at best).
As for the need for metric or decimal in modern industry, again that is becoming less of an issue as machines use binary instead of fractions or decimal, and a machine could not give a hoot as to what units it is programmed in., again as long as the conversion is none, unlike a certain Mars mission.
So lets stop all this bickering as to which is best or worst, in the end we will all go metric that is inevitable, but there is plenty of life left in the old system for those who wish to use it and there is metric for those who don’t.
How much time has been wasted trying to get folks to “modernize”, when they should have been out actually making something, as I have found recently, life is too short for very petty in-consequentialities.
Go forth and make something and hang the units involved.
So endeth today’s lesson.
chriStephens
