There is a rage on tooth belt drives Michael
Even a claim that they even out tooth error and don't stretch etc and can be used up to 10,000 rpm so must be wonderful. Really the base problem is the number and size of gears that are used up to the final axis drive. They tend to be rather small early on so rotate at pretty high rates in terms of astro photography exposure times so the slightest wobble causes drift. People with good technique and autoguiding still produce amazing results with them. Some spend more and more on mounts. Some stick with exposures that are as long as possible. People also get good results without even doing that particularly with dslr's.
The old rule on ideal worms wheels was diameter >= the diameter of the scope being used.
Neil, many have made them with a fair degree of accuracy, allowing them to rotate freely as they are cut seems to be the key and that goes back to pre wwii. At some point I will try a trapezoidal tap with a good tapered lead in which should get round initial engagement problems. Old advice using home made hobs was to wind in quickly. A metric tap as they are cheaper from china than acme usually is.
I own a mount by Meade that Astrophysics used to work on and rebadge – they did 2 main things. Lapped the worm and changed the goto software. Also mounted it on a hefty pier. Considering what is around now I decided to stay with it for if I need a mount this substantial. People are locked into tripods too. Any one who has owned a Vixen GP pier would realise that they are light portable and very stable. In fact I reckon they are quicker to set up too. Trying to get the top of a tripod dead level is a real pain.
