Posted by vintage engineer on 16/10/2019 21:39:22:
I am rebuilding a 1910 5 litre petrol engine. On start up the oil pressure peaks at 70 psi but the running pressure is 15 psi.
Why?
Is this because the oil is viscous when it is cold, or perhaps the engine is a bit tight yet and will slacken off when the running in process is complete.
Cure the problem, not the symptoms.
I'm uncomfortable with the idea of dumping oil flow back to sump during start-up, that's when you most need the oil in the bearings where it belongs. High pressure on start up suggests the oil isn't getting where it needs to be – or at least not in the quantities it should. I'm assuming the oil pump is a positive displacement device so the rise in pressure indicates a restriction in the flow around the engine. If it is actually caused by the oil being a bit thick and treacly when it is cold then there are other oils to choose, at least for the running in phase.
I'd fit a higher scale pressure gauge as a temporary measure and see how this problem develops as the engine hours accumulate.
HTH Simon
