Thanks for your comments, guys, and also for the book suggestion.
I already have a wraparound face shield with brim from another DIY project, which I was intending to use (safety specs tend not to really work for me as I have prescription glasses). Besides the usual no jewelry or long sleeves, that should be sufficient PPE, right?
You are right that 35kg sounds OK for me to move, my day job sometimes involves lifting servers of similar weight. I didn't see the mention that in the description earlier!
Ill also try not to get Gear Acquisition Syndrome. What did you mean when you said "and a tail stock", I was under the impression it came with one? – I was indeed thinking about picking up a small selection of HSS tools , a live (revolving) centre, to start, then maybe later a drill chuck/arbor and centre drill, more tools etc… (oh and of course some aluminium bar – 6061?).
Are any of the addons like quick change tool posts worth it at this stage?
Never ground before, so a little unsure about that, so ill need to do some reading on that too!
Two major questions before I buy:
Finally, I can just plug it into a normal plug right (no three phase inverter nonsense?), and secondly, Metric or Imperial? – I don't need to machine any specific threads to fit anything, so I guess I can just pick whichever?
