Alan,
In the first para of my post at 17:42 I referred only to the thread size, not the respective register sizes. If we take the 'nominal' thread size to be 1.1250", Norman's actual spindle thread size at 1.1226" is 2.4 thou under nominal. Further, Norman's MT2 adapter has a thread diameter of 1.1258" and the thread diameter of his lathe spindle is 1.1226". Thus, the difference between the largest and smallest thread diameter in his set of devices is 3.2 thou. This is roughly comparable to the thread size variance of 4 thou found among my own 3 specimens.
We're all agreed that Myford register sizes in the tested specimens match or very closely approximate to nominal.
Norman,
I agree that we want an 'easy' thread fit between the spindle and backplate threads so as not to constrain the recess from seating correctly on the spindle register. But it's a question of degree.
Take the case of of a novice presented with your equipment, charged with preparing a backplate and who, crucially, takes your Myford spindle blank as a reliable gauge. Relative to your spindle blank's thread size of 1.1240" lets say he adds a couple of thou for clearance, achieving an effective size of 1.1260". When offered up to your actual spindle nose (thread size 1.1226" the backplate will rattle home nicely but the overall thread clearance will be 3.4 thou. Arguably, that's too much but might well be acceptable.*
Now take my case. Relative to my spindle blank thread, sized at 1.1210", the novice likewise adds a couple of thou for clearance, achieving an effective thread size of 1.1230". Trouble is, my lathe spindle is sized at 1.1250" so when presented with this backplate, it just ain't gonna go! Poor old novice is going to have to remount the backplate, somehow pick up the thread and pare or chase off another couple of thou, while praying that he achieves a fit at the next removal.
All I'm saying is that these spindle blanks can't be treated as gauges when preparing backplates unless there's close correspondence in the measured thread sizes of target spindle and blank. If not, then I suggest it's preferable to prepare a gauge based on the actual target spindle.
* I'm a cut and try kinda guy so I'd actually do this job using a reliable gauge and a process of fit and feel rather than measurement. It may be that the clearances I've used in the above examples are unrealistic in real world terms. I'm happy to accept correction on that.
Joe
Edited By joegib on 19/10/2012 10:56:14
