Just splashed out on a precision instrument
Home Forums Workshop Tools and Tooling Just splashed out on a precision instrument
Viewing 7 posts - 26 through 32 (of 32 total)
  • #329422
    Brian Sweeting 2
      @briansweeting2
      Ho Ho indeed yes
      Nigel Bennett
        @nigelbennett69913
        But that's a bog standard one…
        #329440
        Mike Poole
          @mikepoole82104
          Looks rather luxurious with the soft paper, should have Izal or newspaper.
          #329444
          alan ord 2
            @alanord2
            SillyOldDuffer :- after "SPLASHING OUT" I hope you weren't feeling flush!!!!!!!!!!
            #329686
            Men Ifr
              @menifr84251
              I bought one of these a few weeks ago – went to use it for the 2nd time and it's broke. So I would see it quite a few times while you can still get a refund to check it's going to be OK. I've applied for a refund and should get one or another one sent out. I'm having no luck recently buying stuff!
              #329693
              Chris Trice
                @christrice43267
                That'll be another trial and error purchase then.
                #329824
                Men Ifr
                  @menifr84251
                  The problem is I don't have tens of thousands to buy a high end version of all the stuff I use so will be ordering another cheapo as I'll get a refund for the damaged one if that breaks as well I may start wondering but I can't be that unlucky can I?
                  I bought a 300mm digital caliper new for £18 which needed the zero button pressing 10x for it to zero. I got a refund for thatbought another from a diferent seller and that works perfectly in my Z axis DRO.. still only cost me £18 but is a bit of a pain chasing refunds sometimes… you have to be dilligent.
                  Sometimes you can buy expensive stuff and that doesn't work either £70 for and ER20 collet set – no good but has been refunded.
