Last time this was discussed, I posted a link to the sort of thing you are thinking of, although for 40 taper. Of course, it's a specialist / minority sport and thus would be grievously expensive even if it existed in the size you want. Nick Hughes also posted a link to something vaguely possible.
Most 30 / 40 tools seem to have a minimum gauge length of around 50mm, so you are probably stuck with that unless you have deep pockets. The machines with R8 tapers (eg most Bridgeports sold in the US it seems) allow almost zero stickout from the spindle nose. I assume it's not an option to change the spindle here – but most machines at least allow you to move the knee or head quite a distance. You don't say what your machine is – when do you find you are running out of distance?
For CNC knee-type milling machines like mine, the limited quill movement (120 – 150mm typically) can be a major bind. Part of the solution there is to minimise the range of tool lengths used on one job eg a small cutter in a small collet chuck will have little overall length, whereas a jobber drill in a keyless chuck will be much longer. So I am trying to use stub drills and ER16 collet chucks where possible. That approach might help you in some situations.
Murray
