Good Evening, can someone help please ?
I have my mill, which has been overhauled , has run happily with its new motor on the VFD, starting and stopping via the VFD control panel. When the mill was built back in the 1960's it had a 2 speed motor operated via a switch with high low and off … I would like to use this switch to control the VFD , possibly to run the motor at 2 different frequency settings so high is 50Hz and low is 25HZ can anyone help please thank you
Edited By Jerry Bland 1 on 08/11/2020 19:53:14
Edited By Jerry Bland 1 on 08/11/2020 20:33:15
