Holding a ring on a lathe.
Home Forums General Questions Holding a ring on a lathe.
  • #23699
    Chris Denton
      @chrisdenton53037
      Chris Denton
        @chrisdenton53037
        I need to hold a short ring shaped object on the lathe. It is around 4mm long and both sides need to be faced and chamfered internally and externally.
        Whats the best was to hold this, my three jaw doesn't really hold it well enough.
        #178150
        mechman48
          @mechman48
          Make yourself a set of soft jaws, drill pilot hole, bore to suit ring diameter, voila!
          George
          #178153
            Soft jaws. See MEW issue 52.
            martin perman 1
              @martinperman1
              I would like to see the article in issue 52, can anybody send me a PDF copy please.
              Martin P
              #178164
              Dennis D
                @dennisd
                You could try making a Pot Chuck **LINK** I recently made one for a 3/4 OD x 1/8 cylinder end cover which needed a boss on one face and recess on the other.
                #178167
                pgk pgk
                  @pgkpgk17461
                  Is that 4mm before or after refacing? What diameter?
                  A thought from a newbie: How about boring a centre hole out of a length of scrap ally, popping 2-3 1.5mm setcrews around the diameter to hold the work in there while you face and internally chamfer then drill a threaded hole inside the bar, to fix a truncated cone to clamp onto the internal chamfers and chamfer the outsides? Set screws will be reduncdant now and you can chamfer the fixture away.
                  #178168
                  Roger Williams 2
                    @rogerwilliams2
                    Hello all, if you have a lathe that takes 5c collets, you could use one these, a Master Expanding collet. One came with my lathe, but have never used it !.
                    #178175
                    Jon Gibbs
                      @jongibbs59756
                      Some of these methods look pretty good to me but as a newbie I've also read all sorts of stuff about balancing the compression on the chuck jaws along their length to prevent bell-mouthing.
                      Is my information out of date or am I just fussing unnecessarily?
                      Jon
                      #178176
                        You cheeky monkey Martin!
                        Buy a copy at WH Smith and help me pay my mortgage!
                        mick70
                          @mick70
                          Neil is there anywhere to buy the articles you want with a list?
                          not good with comps so prob just missed it.
                          seen few posts listing specific issue and thought that might be worth read.
                          cheers
                          #178178
                            Posted by Neil Wyatt on 02/02/2015 15:06:50:
                            Does WHS stock old back-issues ?
                            I thought you would want to deal direct.
                            Edited By Michael Gilligan on 02/02/2015 15:19:56
                            #178179
                            martin perman 1
                              @martinperman1
                              where would I get a copy of MEW 52 when we are in the 200's now, I'm housebound with a broken foot in a village and six miles from the nearest W H Smith.
                              Martin P
                              #178180
                              V8Eng
                                @v8eng
                                MEW issue 52,  are you sure about that?
                                Way back in 1998 I think.
                                Edited By V8Eng on 02/02/2015 15:21:49
                                #178183
                                  Its actually PAGE 52 of No 224 which is in the shops or just gone.
                                  MHS may well have back issues.
                                  #178185
                                    Posted by JasonB on 02/02/2015 15:49:29:
                                    Good job he didn't buy a copy of Issue 56 then. devil
                                    Harold Hall 1
                                      @haroldhall1
                                      Chris
                                      You may find the pages on my website about using soft jaw helpful. However, it would be nice to know how big (internal and external diameters) the ring is to see if it is a practical method.
                                      The pages are athttp://www.homews.co.uk/page100.html
                                      For anyone who may like the challenge of making a set, or two, see here **LINK**
                                      Harold
                                      Edited By Harold Hall 1 on 02/02/2015 16:54:53
                                      #178197
                                      Nicholas Farr
                                        @nicholasfarr14254
                                        Posted by Michael Gilligan on 02/02/2015 15:52:32:
                                        Hi Michael, especially if he wanted to read something in issue 52. crying
                                        Regards Nick.
                                        #178201
                                        mick70
                                          @mick70
                                          Just been having rummage in scrap box and found some ail hex bar .
                                          So I see project for me and my little girl as she wants to make something .
                                          #178202
                                          mick70
                                            @mick70
                                            Should say Ali
                                            #178203
                                            Muzzer
                                              @muzzer
                                              The OP says "both sides need to be faced and chamfered internally and externally." That presumably requires both internal and external work holding.
                                              I imagined soft jaws to do the facing, boring and internal chamfering, followed by an expanding arbor to complete the external chamfering (and turn the outside surface, presumably).
                                              #178204
                                                If its 4mm thick you can have a 2mm recess in the softjaws which would be ample to put a small chamfer on the OD as well as bore and chamfer the ID all in one go
                                                #178332
                                                  For future reference, there are plenty of MEW indexes (indices?) out here, just google for them.
                                                  If it's a single recent issue you want go to MyHobbyStore and put MEW and the issue number into their search facility.
                                                    Posted by Nicholas Farr on 02/02/2015 17:19:29:
                                                    Cheers, Nick
                                                    blush
                                                    A "digital" problem on my part
                                                    … useless Arthritic fingers.
                                                    martin perman 1
                                                      @martinperman1
                                                      Gentlemen,
                                                      In another thread somebody got lambasted for not saying thank you after he forgot to say thank you for being helped.
                                                      I got lambasted laugh for not buying issue 52 currently on sale in W H Smith, this turned out to be incorrect as there are nearly 200 issues since issue 52 and I didnt start getting MEW until around issue 200 so can I expect an apology laughlaughlaugh
                                                      Martin P
                                                      Edited By martin perman on 03/02/2015 18:47:48
