Help! stuart 104
Help! stuart 104
Home Forums Beginners questions Help! stuart 104
  • #362739
    kullboys boys 1
      @kullboysboys1
      Hello everyone
      can anyone tell me if a Stuart Turner 104 boiler will run a ST number 1 engine.
      Thanks.
      kullboys boys 1
        @kullboysboys1
        #362820
        Ady1
          @ady1
          bumpy wumpy
          #362823
          Ian Parkin
            @ianparkin39383
            The big question is How long for ? A number one is a big engine for a little boiler it will start it and maybe run for demo purposes fro a few seconds
            #362828
              Not sure of the details of a 104 boiler, did you mean 504?
              In either case my catalogue does not show any of their boilers being suitable for a No1 but would depends on what you mean by "RUN" is it for display only or to do actual work.
              #363008
              nigel jones 5
                @nigeljones5
                If you are indeed refering to a 504 boiler then not a chance. As a spirit fired boiler it is relatively low output. If you were to add two of my brass burners you might stand a chance but even then it wouldnt run for long. At 3.5" diameter by 9" boiler barrel theres a lot of water with not a lot of heating surface area. And as for my twin flue 5" boiler – same response, simply not big enough. With a 2" bore x 2" stroke you are looking at a very powerful (1/2 hp) motor which needs a lot of steam. Minimum 6" vertical coal fired would be my starting point. As stated above, it all depends on what you want it to do.
