When I installed my Myford 254 in a room which measures 2.6 x 2.0 m with the door at the end of a long wall, the tricky part was getting the engine hoist out from underneath it. The only possibility seemed to be to leave it on some paving bricks.
Then I had to remove the bricks.
I used a 2-ton bottle jack and a bit of 2" x 2" (maybe bigger) timber. I drilled a hole in the end of the timber so that it could not slip off the jack, and made a notch in the other end. This enabled me to jack up each end separately just enough to remove one brick (or pair of bricks) at a time.
As suggested above, you would need to cut the pallet.
The advantage of my method is that only around half of the weight of the lathe had to be supported.
I would not even think of supporting it under a bar. It could bend catastrophically, or the whole rig could topple.
