> No doubt the 3ph 220v conversion with inverter would transform,
Only if the machine is capable of taking the increased loads. It is, but the extra work rapidly exposes poorly ground or blunt tools. Oddly, I would have expected the lower power setup to be more critical, but the truth is the basic lathe is best suited to HSS tools and relatively light cuts.
My machine was a Machine Mart return, but for all the things I have done to it, there was only one 'fault' that I have corrected, it faced slightly convex, and one fault I have not corrected which is the loose fit of the tailstock barrel (because the spilt clamp locks it repeatably in place anyway). I blew a motor because I was running it at about 60RPM facing 6"x4" cast iron with an over-rated fuse. The control board went because a long snake of swarf got into the control box – this was after about 11 or 12 years use.
I would probably not have got into the hobby if I hadn't found this machine, so I must stand up for mini-lathes as in my case at least, they have proven life-changing.
Edited By Neil Wyatt on 16/10/2014 15:19:23
