Posted by Clive Hartland on 23/11/2017 15:56:32:
I am not sure where you are getting data about life of military weapons, A tank barrel has a life of 100 Discarding Sabot heads but 20,000 of low velocity Hesh. The same with a field gun, standard charges 20,000 .EFC's
No I believe that's about right. I think the source of the 20 minute lifetime was Janes. 100 rounds in 20 minutes is 5 rounds per minute.
Even in WW2 British artillery was organised as a system allowing all the guns in a division or even a corps to plaster a single target. Back then it was done by officer observers and radio and it was quite difficult to spot individual enemy guns. Firing a well camouflaged field-gun was relatively safe. Today it is only safe to shoot at unsophisticated enemies. All major armies are able to determine point of origin with fast accurate methods like radar tracking shells in flight coupled to GPS. So the life of an artillery piece depends on how quickly it attracts a response. As aircraft, drones, missiles, or artillery all have accurate coordinates to aim at the gun won't last long once it's been identified and prioritised. For the same reason, if you're going to fire a gun, it pays to maximise it's effectiveness by shooting at targets as quickly as possible. Otherwise you get blasted after a few minutes having achieved very little.
In the second Gulf War the allies inflicted huge damage on the less well equipped Iraqi's mainly because sophisticated command, control and communication coupled with accurate targeting and precision weaponry destroyed most Iraqi heavy weapons before they were able to fire.
Scary stuff. Guy's early tank must have been terrifying when it first appeared. It was just the start – the way high-intensity military effectiveness has multiplied since 1918 is horribly impressive.
