First Len, an apology for not taking up
earlier your wish for my thoughts on the subject of this thread.
Whilst I visit the forum quite often to acquaint myself with the new
subjects being discussed I rarely find the time to read them all in
detail. Having now found your request I will attempt to give my
thoughts on the subject, I hope not too late.
Firstly, in a nut shell, I have never
considered grinding on the side of a wheel to be a total no no. This
though based on using it for tool and cutter sharpening and any other
task EQUALLY light.
Cyril’s comments from his Norton hand
book are very interesting in that they do not consider it totally
unacceptable. Similarly, my Universal Grinding Wheel Co handbook
(1989), whilst warning against using a wheel for heavy tasks, it is
not adamant that they cannot be use for lighter tasks.
My advice therefore is, that it is OK
for tool and cutter sharpening and anything of a similar duty. This
will though result in the need to dress the side of the wheel from
time to time, though in the home workshop not that often, reducing as
a result its width. It is impossible for me to be exact, but as a
guide line I would suggest, that when a 16mm wide wheel had been
reduce to 12mm it is time for a new wheel, and definitely no heavy
grinding work to be undertaken on it, front or side.
If your workshop activities include
dressing welds and rough castings then these are tasks for the outer
diameter and would recommend two grinders, one for rough usage and
the other for tool sharpening.
In this case, equip the grinder with
wheels specifically made for the task. These have a white grit (not
sure at the moment of the correct terminology) and cut so much better
that the wheels for every day use. They could then be Cup and Saucer
wheels, these shapes are beneficial but not essential. See
http://www.homews.co.uk/page225.html
It is worth noting that if sharpening
tools is done using a tool and cutter grinder or one of my grinding
rests, most sharpening is neither done on the outer diameter or the
side but the corner of the wheel.
Something a little more technical
Most will realise that when removing
metal with an abrasive the larger the surface the greater the
pressure required for the abrasive to be effective. Taking then a
simple example of grinding the end of a 20mm square bar, (400sq mm).
If though it is applied to the outer diameter of the wheel it will
only be a line contact, say 2mm wide (40sq mm)
With the workpiece is then applied to the side
of the wheel, not only will it be using the wheel in its weakest
plane but much more pressure would be required. Hence the reason for
it not being acceptable to use it in that way.
Another point worth considering is that
many off hand grinders do not have wrap around rests so there is no
support for the workpiece on the side of the wheel. This must be
attended to even for tool and cutter uses.
Finally therefore, using the side in my
estimation, tool and cutter sharpening with suitable rests, OK, heavy
duty tasks, NO!
Harold
