The traditional formula for calculating RPM of either the job in the lathe or the outer edge of a milling cutter is
RPM = 4 x Cs/D
where Cs is the cutting speed in feet per minute. 100 for mild steel. 60 for cast iron. 200 for brass and ally.
D is the diameter of the job, or the milling cutter OD, in inches.
So you get 4 x 60 divided by 3, which gives as near as dammit to Jason's 85rpm. Just so you know how to work it out for future jobs.
The shortcut way is to divide 400 by the diameter in inches. Then for cast iron, halve the answer. For brass or ally, double it.
Edited By Hopper on 06/03/2018 11:22:30
