Posted by Chris Parsons on 17/12/2012 13:33:37:
I am eagerly waiting for Santa to deliver my first lathe (hopefully on Thursday) and have some 'getting started' questions?
I have some 'Copaslip' but presumably it would be a good idea to also buy some slideway oil? Do I use the this same oil in the oil ports, and to replace the protective grease removed after cleaning? Is car engine oil or 3-in-1 not suitable?
Thanks
Chris
Hi Chris,
Congrats on getting your first lathe. Don't worry too much about the legendary casting sand, I have had none in any of my Chinese Machines – 4 so far – even my ultra cheapo Seig C0 was good and clear of grit. After inspection I just cleaned off the anti rust grease (usually lanolin wax or similar) with white spirit and then alcohol to get it spotless and lubricate with a suitable lubricant such as has been suggested. I have found no problem with the factory adjustments of gib keys etc.
The reason motor oil is frowned upon is that it contains detergents, which in a vehicle helps to keep the sludge etc in suspension until it can be filtered out, as well as other additives. In a lathe there is no filter and the lack of detergent allows the sludge and damaging particles to fall to the bottom of the gearbox where they are relatively harmless. A few years of occasional use probably will cause no problem but for the low cost of suitable oil ask yourself – 'is it worth the risk'? You won't know until your bearings wear out and then blame the manufacturer. 3-in-1 is, in my opinion too low a viscosity to be of much use in a machine (except sewing machines etc with relatively light loading), but I stand to be corrected.
Copaslip is really just an anti sieze grease with a high melting point so that it can be used where parts are to be disassembled infrequently or in high temperature situations such as the sliding surfaces of brake pads and shoes (only a smear) where little actual movement takes place. It is anti corrosive so can be used on screw threads to prevent siezing, it has little use for greasing where movement takes place. To quote the manufacturer – "Copaslip is an anti-sieze pre-assembly compound for use in any temperature from sub-zero to 1100ºC " see here for the data sheet
Personally, I use high pressure dry lubricants for my slideways – including cross slide etc and in some other areas of my machines, they don't attract particles that the heavier oils and trad. greases do, and if it's good enough for NASA, it's good enough for me – and it's my problem if they fail to do the job, but so far no problem. They are not cheap but neither was my lathe. I use recommended machine oils (or 'equivalent' as they say) for some oiling points.
I use camellia oil for rust proofing when leaving the machines for any length of time just a wipe over is enough. The Japanese have used it for protecting tools and swords for centuries and it works.
Best regards and enjoy your aquisition,
Terry
