Farm Boy
Farm Boy
Home Forums I/C Engines Farm Boy
Viewing 22 posts - 76 through 97 (of 97 total)
  • #747765
    Ian Hewson
      @ianhewson99641
      Hi
      As you have found, they are close, but there is enough meat in the taper for them. It needs carefully measuments when turning the boss, I nearly made them too small and had the same problem.
      Fortunatly the tapered wedges cover any viewing.
      Ian
      Dalboy
        @dalboy
        On Ian Hewson Said:
        Hi
        Ian
        Yes they certainly are close but as you say due to the taper there is plenty of meat for the screws to hold them in.
        #748276
        Ian Hewson
          @ianhewson99641
          Couple of pics of my finished Farm Boy.
          IMG_0625IMG_0628
          #748355
          Dalboy
            @dalboy
            Very nice Ian. I hope mine turns out like that
            #749033
            Dalboy
              @dalboy
              Managed to get the Fly wheel locking collars completed and could not resist a part dry fit with they in place.
              Fly wheel part assembly (1)Fly wheel part assembly (3)
              Fly wheel part assembly (4)
              Fly wheel part assembly (5)
              I have been putting off cutting a test tube to complete the oiler for the engine. So I tried to use a glass tube cutter which failed, and it shattered, so a good clean up and vacuum got rid of the broken bits. Next I wrapped the tube in some masking tape (I have about ten tubes as that was the minimum I could get at the time) this was gently gripped in the lathe yet strong enough not to slip, a Dremel was used with a small diamond disk and a short section soon parted ways from the tube. This section was rubbed on some very fine wet and dry paper to get rid of any sharp edges (With the tablets I am on if a cut myself it takes forever to stop)
              As most of the parts were already made from brass, the only other part was the control needle, which is from silver steel (tool steel depends on where you are in the world). This needed a point on one end and then cut to length and fixed into the top adjustment piece.
              The complete oiler ready for the engine once completed as there are still bits that need making. Without measuring it I would say between 1 1/4″ to 1 1/2″ tall.
              complete oiler (5)
              complete oiler (4)
              A question about the oiler if you make your own what do you use to seal the glass tube to prevent oil leaks
              #749035
                A couple of models I have made supplied cork “washers” about 1/32″ thick. But gasket paper would probably do as would liquid gasket, you can get a clear one.
                #749051
                Dalboy
                  @dalboy
                  Thank you, Jason
                  #756676
                  Blue Heeler
                    @blueheeler
                    Thoroughly enjoyable thread.
                    #756951
                    Dalboy
                      @dalboy
                      Glad you are enjoying this build. Things have slowed a little as one part I am remaking for the third time down to my silver soldering I have followed numerous people and still managed to stuff it up, I will get there in the end.
                      #758011
                      Dalboy
                        @dalboy
                        After two failed attempts at the governor assembly, I manage to silver solder the two arms on and now happy with the outcome.
                        Now onto some other small parts and a base for it to sit on so that I can attach the flywheels.
                        Gov assembly
                        Gov assembly. 3Gov assembly. 4Gov assembly. 5
                        #758528
                        Dalboy
                          @dalboy
                          After making some pins I am able to do a test fit of the governor assembly hopefully this makes a little sense where thing go
                          gov assembled (1)gov assembled (8)
                          #763922
                          Dalboy
                            @dalboy
                            Not done much lately. But I have made a start on a fuel tank. Turned the main body and ends which is a cylinder at the moment need to make a filler cap and fuel cut off outlet.
                            Tank sitting on two blocks which will become the supports
                            fuel tank support (2)
                            The supports cut from a larger piece which had some holes luckily the hole shown is machined out
                            fuel tank support (3)
                            Here I had machined out the bulk of what was not needed ready for some shaping.
                            fuel tank support (9)
                            After machining the curved section, they are now a lot shorter but still leaving enough room for an outlet from the tank.
                            fuel tank support (4)
                            By machining them instead of using solid blocks makes for fixing to base and tank a lot easier as well as lightening the appearance of them.
                            A test fit of one of the supports, not sure which will look better, the foot facing in or out. Facing in would give a little more room for the outlet if I need to work on it when it is complete.
                            fuel tank support (7)
                            fuel tank support (6)
                            #769767
                            Dalboy
                              @dalboy
                              More work on the Fuel tank. First a little late I managed to get both stand uprights completed all except the fixing holes. As well as the end cap fixing screws.
                              Fuel tank 2 (2)
                              Onto today drilled the filler hole and fuel outlet this was threaded 1/4″ x40. Turned some brass for the outlet elbow and did the same method as I did for the carbaretor elbow by milling at 45deg most of the way through heating and bending before silvers soldering.
                              Fuel tank with outlet fitted (1)Fuel tank with outlet fitted (4)
                              Twisted the tank upside down to show outlet pipe in position. I need to take apart to clean swarf out of the inside
                              Fuel tank with outlet fitted (5)
                              #788401
                              Dalboy
                                @dalboy
                                Now that I have the tool which I showed in another thread, I have managed to get into the workshop with orders from the wife just to give me a break from my other duties.
                                The tool I speak of is the spring winder I now have the valve springs made for the engine. I may remake the valves again as I am not happy with them.
                                Anyway, picture of the valves, springs and caps. This is the first attempt at making springs
                                Valves and springs
                                #788423
                                  On Dalboy Said:
                                  […] This is the first attempt at making springs
                                  That looks very encouraging
                                  P.S. __ I do like your fuel-tank supports.
                                  #788476
                                  Dalboy
                                    @dalboy
                                    Thank you, Michael, I did have to think of the best way I was going to fix the supports I could have used a solid support, but I felt it would look too heavy for the size of the tank.
                                    #797366
                                    Dalboy
                                      @dalboy
                                      Just a few photos and what I am halfway through on the engine.
                                      First a picture of the spring I made in position on the head.
                                      head complete with home made springs
                                      And all the ignition bits and bobs as well as the spark plug, a 1p piece for scale.
                                      ignition wiring an spark plug (1)ignition wiring an spark plug (3)
                                      And finally, a part machined plastic piece to hold the wiring and sensor. A magnet will be in a part attached to one of the flywheels, which I have yet to make.
                                      wiring harness instulation (2)
                                      wiring harness instulation (1)
                                      Still needs some machining, but this shows where it will fit
                                      #799878
                                      Dalboy
                                        @dalboy
                                        Been machining the fly wheels today first was the governor flywheel drilling and tapping the holes for the governor weights and machining the groove on the inside.
                                        Onto the second flywheel again, milling a groove on this one also. This was followed by drilling a hole in each spoke to hold the pulley that fits on the side. While it was set up, I milled the seat for some small blocks which the pulley will eventually fit onto. These are attached with some JB weld now, waiting until tomorrow before drilling for a bolt to secure them so that I can turn a curve on them
                                        fly wheel machining for pulley (2)
                                        Machining the flats for the mounting blocks
                                        fly wheel machining for pulley (3)
                                        #800120
                                        Dalboy
                                          @dalboy
                                          Final work on the last flywheel before painting.
                                          After leaving for a good 24hrs for the JB Weld to set and securing with bolts from the back the step to align the pulley was machined. (I forgot to photograph, so this is just mocked up)
                                          flywheel pulley final drilling (4)
                                          Locked the flywheel down onto the pulley removed the original bolts and drilled a clearance hole right through and fitted the bolts to secure the pulley.
                                          flywheel pulley final drilling (2)
                                          Turned over with the bolts the right side still need to secure them as waiting for some nuts to arrive
                                          flywheel pulley final drilling (6)
                                          As can be seen this was made easier by the use of the platter I made, well worth the effort making it
                                          flywheel pulley final drilling (7)
                                          Next job they need painting
                                          #800880
                                          Dalboy
                                            @dalboy
                                            Made a start on the base unit for the engine today, put both pieces through the thicknesser and the large base over the surface planer, bringing both to size and square.
                                            base started (4)
                                            Marked out the bottom for some hollowing out where the electronics will sit out of sight. Not worried about the knot as most of that will be removed from the bottom and the small amount that is on the top will be hidden under the other piece.
                                            base started (5)
                                            Test with the engine in place to see how it will look, I will chamfer all the main base edges top and bottom to give the appearance of a thinner base.
                                            base started (3)
                                            base started (2)
                                            base started (1)
                                            #800882
                                            Roderick Jenkins
                                              @roderickjenkins93242
                                              That’s looking really smart.  Nearly there!
                                              Rod
                                              #800902
                                              Diogenes
                                                @diogenes
                                                👍..watching with interest ‘cos I’m going to have to do one soon and I don’t have any woodworking equipment apart from HSS shell mills..
                                              Home Forums I/C Engines Topics
