Cutting an unlisted thread on colchester student
Home Forums Manual machine tools Cutting an unlisted thread on colchester student
  • #378767
    Ian Parkin
      @ianparkin39383
      How do I cut a 1.75mm or 3.5mm thread on my imperial colchester student
      The thread plate lists 1.25…1.5…2….2.5…3…4…5…..6..
      So how do i calculate a different gear train…. Which i dont have any extra gears for yet
      If for example i divide 25.4 (1 inch)by 7.5 (tpi) i get 3.3866 where the thread plate lists that setting as 4mm.
      is that the metric/ imperial lever that adjusts that?
      Ian Parkin
        @ianparkin39383
        #378771
        Brian Wood
          @brianwood45127
          Hello Ian,
          One suggestion is to set up for 2.5 mm cutting but interpose intermediate gearing for 35/50 in the gear train. You surely have those gears in your selection. That will give you 1.75 mm; 70/50 will give you 3.5 mm
          I would do an 'air pass' first to check the result before you commit to metal
          Edited By Brian Wood on 02/11/2018 10:36:50
          #378773
          Ian Parkin
            @ianparkin39383
            just the driver and driven with a spare driver 42 twice the size for the smaller tpi's the gearbox covers almost anything i've ever needed
            #378779
            larry phelan 1
              @larryphelan1
              I had to do something similar with my Craftsman lathe in order to cut 1.75 [12mm] and 3.5 [30mm ]. As far as I remember,I set up for some speed but used a different setting of the levers on the gear box.
              Sounds iffy,I know,but I made a note of what I did,for the next time around.
              #378782
              Brian Wood
                @brianwood45127
                Hello Ian,
                You asked how to calculate a gear train to suit these different threads and implied you would be getting the gears needed. I have simplified my thinking, you just need the two gears, 35 and 50 T . To cut 3.5 mm threads you select the gearing for 5 mm with those interposed.
                That is what the maths shows in it's simplest form, I can't do magic.
                #378784
                peak4
                  @peak4
                  Ian, would this forum post assist you at all?
                  Failing that I've finally got a new metric lathe arriving in Buxton on Monday wink
                  As you know from my one trip into your cellar,  I've not used a Student, but but I assume yours is the one with the imperial only gearbox, labelled up as the Dominion on Tony's web site
                  There is also some info on gears required in the manual from p 17 on, which is available on VintageMachinery.org
                  127 teeth are lots of money from HPC, but you could try Bede Tools
                  Good Luck
                  Bill
                  Edited By peak4 on 02/11/2018 11:35:48
                  Edited By peak4 on 02/11/2018 11:45:57
                  #378793
                  Ian Parkin
                    @ianparkin39383
                    Right I'm still confused about what to do
                    whilst it has a imperial leadscrew theres a lever on the gearbox to switch between metraic and imperial threads
                    this is my gearbox table
                    As standard the gearbox is driven by a 21 tooth or a 42 tooth driving a 35 tooth on the gearbox input.
                    on my lathe i use timing belts so to keep the same ratio its a 24 or 48 driving a 40.
                    Can anyone with better maths brains tell me what gears i need or new pulleys to acheive a 1.75 and 3.5 pitch screw
                    Edited By Ian Parkin on 02/11/2018 12:41:53
                    #378794
                      You would need to change the 42T to a 49 and select the 1.5mm setting for 1.75pitch and the 3.0mm setting for 3.5 pitch
                      1.5 x 49/42 = 1.15
                      Edited By JasonB on 02/11/2018 13:04:52
                      #378798
                      Ian Parkin
                        @ianparkin39383
                        Thanks Jason
                        #378800
                          30T on the gearbox driven by the 42T should do the same thing and may be easier to source
                          A 56T pulley driving your 40T pully will also work
                          Edited By JasonB on 02/11/2018 13:23:34
                          #378805
                          Ian Parkin
                            @ianparkin39383
                            Jason
                            your sum above should be presumably
                            1.5 x 49/42 = 1.75
                            not 1.15 ?
                            As its easier to source pulleys than gears what size should the driven one be as i cant fit anything larger than a 48 tooth as the mainshaft is close
                            #378813
                              yes should have read 1.75, Think my fingers were thinking about the 1.16666666 increase in gear box speed you needed.
                              Won't work keeping the 48T pully unless you can find a 34.286T pully to go with it. Other pully combinations are 42-30 same as the gear option or 49-35 if you can squeeze it in. You need any combination that gives 1.4
                              #378840
                              Brian Wood
                                @brianwood45127
                                Ian,
                                You didn't explain originally that you were using toothed belts on this lathe, I was working things out for a gear train, as you requested.
                                To return to your problem
                                Another combination that gives you the multiplier of 1.4 that Jason speaks of is 35 driver–25 driven.
                                #378844
                                Ian Parkin
                                  @ianparkin39383
                                  I do have the original gears (only 3 )but usually leave the belts on as less noise and no need for setting clearances.
                                  so basically I need to set the gearbox to say 1.5mm or 3mm and apply a 1.4 increase to the gear train or pulley ratios
                                  #378848
                                  Brian Wood
                                    @brianwood45127
                                    When I do the calculations again, using a 42 driver and the gearbox settings you will be using, I find that you will need a 36 gear on the gearbox
                                    The sum is 42/36 x 1.5 = 1.75 mm and likewise 42/36 x 3.0 = 3.5 mm
                                    Edited By Brian Wood on 02/11/2018 17:53:58
                                    Edited By Brian Wood on 02/11/2018 17:55:15
                                    #378849
                                      No you need a 1.16666666 increase to the existing which gives a ratio of 1.4, the old ratio from your belts or the gears was 1.2
                                      #379180
                                      Brian Wood
                                        @brianwood45127
                                        Hello again Ian,
                                        Sorry for resurrecting all this again, but I was away for the weekend at a family wedding and to while away the sleepless hours in a strange bed I fell to thinking about your metric gearings from a different approach altogether.
                                        Now back home I was able to check them through. If you gear the lathe as 35/42 rather than the normal way, you get some rather unlikely 'imperial ' pitches, such that setting up for 12 tpi threading will give you a metric pitch of 1.764 mm; only 0.014 mm in error of the 1.75 mm you sought.
                                        And, setting the gearbox up for 6 tpi theading will give you a metric pitch of 3.528 mm, this time in error by 0.028 mm
                                        The multiplication factor 35/42 is the inverse of 1.2 [the normal arrangement of 42/35] which is 0.83333333; you just multiply all the pitch values by that amount.
                                        I leave you to explore the new possibilities this little piece of thinking outside the box gives you
                                        Edited By Brian Wood on 04/11/2018 19:20:41
                                        #379183
                                        Ian Parkin
                                          @ianparkin39383
                                          Thanks Brian
                                          i have ordered some pulleys so I can hopefully cut my 3.5mm pitches
                                          the student handbook does go through how to cut different than what’s in the gearbox but it assumes that you also have a complete set of change gears and the instructions slightly gloss over how to calculate metric pitches
                                          #379187
                                          Ian Parkin
                                            @ianparkin39383
                                            Actually I must try the setting 2 across from 3mm pitch and see what results could there have been a brainstorm in the Colchester factory and they left off 1.75 and 3.5 off the chart which surely were widely used in the 60’s
                                            Ian
                                            #379188
                                            Ian Parkin
                                              @ianparkin39383
                                              Sorry double post
                                              Edited By Ian Parkin on 04/11/2018 19:37:23
                                              #379254
                                                Posted by Ian Parkin on 04/11/2018 19:36:37:
                                                Ian
                                                By all means experiment, but I doubt Colchester got it wrong. The good thing about gearboxes is they provide instant access to common ratios,. The bad thing is that they may not provide all the ratios you need. Covering all possibilities would need a complex gearbox and cost is usually an issue. I don't think it's unusual for ratios to be missing.
                                                As a compromise, my lathe has a 3-speed gearbox allowing me to switch quickly between TPI or metric triplets like 0.75, 1.5 and 3.0 pitch. But, if want to cut any other thread, I have open her up and alter the change wheels. Takes ages and I get covered in grease.
                                                It gets worse. In practice my 3-speed gearbox doesn't help much because the next thread I cut almost always needs a different change-wheel combination! Your gearbox is much better than mine, but it still has the same problem – sooner or later to get the wanted ratio out you have to alter the input ratio. On some lathes this isn't possible at all, or it needs change wheels you don't have, or – if you can't find a table – requires wet-towel and paracetamol mathematics. Jason and Brian's suggestions look good, but you would need to source the gears.
                                                How is threading done by changing pulleys? Presumably a toothed belt?
                                                Ian Parkin
                                                  @ianparkin39383
                                                  Just to update this thread with a solution if any else needs to do this
                                                  (I still cant get my head round it )
                                                  My thread plate
                                                  I used Brian Woods suggestion of swapping driver and driven gears
                                                  So i used the 35 as the driver and 21 tooth as driven
                                                  then with the levers set DA and the gearbox for 20tpi/1.5mm setting and the imperial/metric lever set to imperial
                                                  and leaving the half nut engaged i get a lovely 3.5mm thread s far as i can measure with a pitch gauge over 6 threads but it certainly works with commercialy availble nuts
                                                  disengage the half nuts and it wont go back on the thread previously cut
                                                  Many thanks to all that offered advice
                                                  Ian
                                                  #436293
                                                  Brian Wood
                                                    @brianwood45127
                                                    Hello Ian,
                                                    Thank you for bringing us up to date with the outcome of your experience. It is always gratifying to hear that suggestions have worked, as planned, and that you are pleased with the outcome.
                                                    Happy threading
                                                    Regards Brian
