Cost effective way for manufacturing a small plastic part
Home Forums Beginners questions Cost effective way for manufacturing a small plastic part
Viewing 25 posts - 1 through 25 (of 38 total)
  • #290990
    John Munroe
      @johnmunroe13164
      Hi
      I'm trying to have about 2000 pieces of this nylon part made:
      It's a small rectangular piece with 2 holes in it. Does anyone know of a cheap way for manufacturing? How about laser cutting?
      Thanks
      Edited By John Munroe on 29/03/2017 07:14:24
      John Munroe
        @johnmunroe13164
        #290991
          I would think that would cost more than manual machining.
          Assuming you can get 1" squae bar, I would set a stop on a chop or crosscut saw saw and be able to cut them to length very quickly. Simple locating jig on a drill press (you don't state tollerance on hole) and drill one set of holes, change drill and do the others
          #291001
          not done it yet
            @notdoneityet
            Apart from needing 40mm square bar, I agree with JB, assuming units shown are in centimetres.
            #291002
              Posted by not done it yet on 29/03/2017 09:00:01:
              Interesting assumption dont know
              … I was about to ask for confirmation of the units
              [having first thought them likely to be millimetres]
              I suppose it depends how you think of "small"
              Chris Evans 6
                @chrisevans6
                That is not an easy task, is it a regular plain nylon or glass filled ? My concerns are not the cutting and drilling but trying to get the nylon to cut cleanly without leaving a burr.
                #291004
                John Munroe
                  @johnmunroe13164
                  No, the units are in millimetres.
                  #291006
                    Ah, now I have blown up the screen that 1 is actually 4, so I'd say its cm but as Michael says there is small and there is small so could be 4mm sq in which case a circular saw would tend to throw the parts about.
                    #291010
                      Posted by John Munroe on 29/03/2017 09:08:42:
                      … the units are in millimetres.
                      Thanks for that important clarification, John
                      Next question [which Jason has already mentioned] must be
                      … 'what are the tolerances?'
                      I think you might have difficulty with a 1.80mm dia. hole in Nylon.
                      Bob n About
                        @bobnabout
                        You don't give a tolerance for the part. Assuming you can't find an existing nylon extrusion, I would route the section from 6mm bar. Each part can be guillotined with a Stanley blade, I would drill the blocks in a jig possibly using a 2mm carbide end mill than a drill. You are probably looking at 21m (x7 3m lengths).
                        If you are likely to make more of these, look into extruding your own section and punch the holes out whilst the nylon is still warm and in the die. Kind of like a giant 3D print head, you're almost at the point of injection moulding.
                        #291015
                        Tony Pratt 1
                          @tonypratt1
                          Obviously 4mm square stock is the ideal material if you can get it, maybe jig drill the holes then cut off to finished length or cut off to length & drill the holes? Deburring will be tiresome.
                          Tony
                          #291018
                          John Munroe
                            @johnmunroe13164
                            I'm hoping to achieve a tolerance of 0.05mm. Is it too tight?
                            #291022
                            richardandtracy
                              @richardandtracy
                              2nd hand hand injection moulder & home made tooling, and sell the moulder afterwards? There is a Gingery book on it to give an idea, but the biggest problem is buying the material to be injected. Well nigh impossible on a small scale.
                              Hmm seem to be arguing against my own idea.
                              What value can you extract from each, and is there a possibility of future manufacture? May be more cost effective to pass on the job or let someone else have the agro.
                              As for the tolerance you are specifying, that's tight enough for a plastic to need to specify the temperature and material water content at which it's to be measured. Some types of Nylon can shrink by 10% when going from saturated to dry.
                              Richard
                              Edited By richardandtracy on 29/03/2017 10:22:38
                              #291024
                              Bob n About
                                @bobnabout
                                You can buy Nylon on a roll suitable for 3D printing, feed it through a bean slicer to make pellets for injection moulding.
                                #291027
                                HOWARDT
                                  @howardt
                                  it is probable best to speak to an injection moulding company. They may have ways to prototype parts at lower cost than normal volume parts. It all depends on what you can afford to spend in money or time. If time is not important but money is then cut from sheet and use a jig to drill both holes from one end datum not the middle as drawn. Forget the length tolerance unless it needs to fit into something.
                                  #291030
                                  Bob n About
                                    @bobnabout
                                    Any reason it has to be Nylon and not a castable resin. Spin casting in resin with steel pins you push out after would make small batches at a time.
                                    #291037
                                    Martin Connelly
                                      @martinconnelly55370
                                      You can get 4mm square nylon strimmer cord. It comes on a reel but a bit of warmth should allow it to be straightened out before use. Due to the problems of drilling plastics with accurate sized holes what are the material requirements you need to meet, something else may be a better option.
                                      Martin C.
                                      #291039
                                        Posted by John Munroe on 29/03/2017 10:10:22:
                                        First point is that Nylon is hygroscopic, and the holes will probably tighten-up.
                                        Second is that, as others have now mentioned; Injection Moulding [done properly] would be the preferred method.
                                        In the early 1970s I worked for Kodak, in Stevenage, and it was truly amazing what they could achieve with injection moulding … BUT … they used very big, very expensive, machines and the set-up time was often a couple of days. To achieve the required quality; temperature and pressure need to be right [and very stable!].
                                        An injection mould with two holes at right angles could prove expensive, but I think you might explore the possibility of moulding a precision part with one hole, and then drilling the second hole as a 'second operation'.
                                        I've been away from that business for about 40 years, so can't advise regarding current Suppliers' capability.
                                        Brian G
                                          @briang
                                          Have you tried the estimators on http://www.custompartnet.com **LINK** ?
                                          Edited By Brian G on 29/03/2017 11:14:32
                                          #291047
                                          Bob n About
                                            @bobnabout
                                            There above is a 10 x 10 x 10 array with 2mm spacing and a 2mm joiner in Z for SLA printing. The whole thing is 60mm x 60mm x 120mm tall. Two of these prints would give you your 2000 parts. In the long run this is probably the quickest and cheapest method.
                                            #291048
                                            Bob n About
                                              @bobnabout
                                              P.S it you buy me an SLA printer I will do them for FREE cool
                                              Holes should be treated as approximate size.
                                              #291049
                                                Joules,
                                                That looks very impressive
                                                Please forgive my innocence in these matters, but: could a 3D Print be reasonably expected to hold the hole diameter to 1.80 +/- 0.05 mm ?
                                                Bob n About
                                                  @bobnabout
                                                  No, it couldn't so each hole would need reaming to final size. Also I doubt the whole print could hold that tolerance. But considering the time saving and the fact an 3D SLA printer can be had for just over £1k it's a pretty good trade off, with no tooling required other than a reamer.
                                                  #291053
                                                  Tony Pratt 1
                                                    @tonypratt1
                                                    Ok guys how long to print one of these parts?
                                                    Tony
                                                    #291058
                                                    Bob n About
                                                      @bobnabout
                                                      One, or the array ?
                                                      The array can be printed in several hours and all 2000 in one session to fit the print bed. Resolution is a big issue at 100 micron in XY and 25 micron in Z Then a day or two doing the clean up and reaming/sizing.
                                                      So about £0.55 per part.
                                                      Worst still the resolution in XY is 300 micron (0.3mm)
                                                      Edited By Joules Beech on 29/03/2017 12:24:24
                                                      Edited By Joules Beech on 29/03/2017 12:30:43
