Colchester student 1800 lathe
Home Forums Manual machine tools Colchester student 1800 lathe
  • #145591
    Anthony Collins
      @anthonycollins76052
      Hello I'm new to this forum so please bear with me.
      I am trying to remove the bed piece from my gap bed lathe. I have taken out the three holding bolts but it will only lift 1/2 mm . Has anybody else had this problem.
      Help!
      Anthony Collins
        #145600
        Ady1
          @ady1
          Early students had 4 allen screws and no dowels
          Two vertically from the top, two horizontally, one in each outer edge
          Edited By Ady1 on 01/03/2014 10:50:45
          #146093
          Nigel McBurney 1
            @nigelmcburney1
            My Colchester Master 2500 virtually the same as your lathe has 5 screws holding the gap piece in place,there are three vertical short cap head screws,and two long horizontal c/h scews. you can use a standard allen key but a 3/8 drive ratchet handle with allen key "sockets " is easier. as there is not much space between the end of the gap piece and the headstock.
