Hi Robert,
The medics obviously have need for more robust tube than we expect – it seems that 1/8" bore silicon tubing for use in pump applications is available with a working pressure of 170psi and a burst pressure of 680 psi. With a minimum radius of under an inch, I would have thought this would be ideal.
Here's another that is 1/16" bore and 200psi working pressure.
Another one claims "At a back pressure of 4 bar (60psi), this pump tube lasts over 1,000 hours with continuous use at 200rpm in a Watson-Marlow Bredel 700series pump. Under transfer conditions, it exhibits 18 times the life of silicone rubber tubing, and nearly twice the life of thermoplastic elastomer tubing with continuous pumping at 360rpm. The risk of premature tube rupture is significantly reduced"
200 rpm is far more than we would need, but it would also be easy to fit multiple tubes within teh same housing/roller arrangement.
