Hi David,
I bought a 1/2" M42 blade replacement for my Warco CY90 ( I think this is basically the same model) from Tuffsaws in February and have received fantastic service from Ian at Tuffsaws; receiving not one but two replacement blades since then!
It seems that their M42 blade stock is perhaps too thick and inflexible for this saw with its tight bends and continuous flexing of the blades back and forth to achieve the necessary clearance. I have broken two M42 blades now at the weld and am now trying one of the Tuffsaw's supertuff carbon steel blades which is thinner and hence more flexible.
Ian tells me that he is trying to obtain some thinner M42 blade stock which he hopes will work better for these small saws. In the meantime it may be best to ask Ian's advice which blade he recommends for this saw rather than blindly buying an M42 blade for it like I did.
The blade is 1300 mm long and 1/2" wide.
I hope this helps
Jon
Edited By Jon Gibbs on 14/08/2015 11:44:31
