Posted by Fowlers Fury on 14/09/2017 11:19:32:
Dilute hydrochloric will only attack the zinc in the brass alloy, not the copper. The resultant effect on the brass component is minimal. HCl will be much faster than alum. All such agents are effective by corroding the iron in the steel i.e. accelerated"rusting". I've used both and dilute HCl is my preference. The problem though is any HCl vapour causing corrosion of nearby components which wouldn't occur with alum solution. So, cover the area with Clingfilm if possible.
So, bit of a contradiction. I said 'Don't use Hydrochloric Acid because it attacks brass' and Fowlers Fury says 'Dilute hydrochloric will only attack the zinc in the brass alloy, not the copper.'
He's right but dezincification of the brass might matter; it would weaken the thread for example. Slightly more worrying to me is the possibility that Hydrochloric Acid will react with Iron in the tap to make Iron (III) Chloride. Now that chemical is well known for dissolving copper to make printed circuits.
Unfortunately, I'm pontificating from my armchair, whereas Fury has actually done it. As Andrew has two spoiled capacitors to experiment on, would he please try both methods and put me out of my misery?
