I have a Boxford 8 inch shaper. It has the table that can be rotated, so it is a bit unusual.
I would like to cut a vertical surface on the shaper and to do so I would have expected to find a lock on the table such that it could not move horizontally, but I can't find it!
There certainly is a table lock to stop vertical movements of the table.
Has anyone found a solution to this problem, or is it not a problem at all? Is the mass of the table sufficient to not have to worry about it moving, or do I need to make up some "table stops' that fit the horizontal dovetail slide on the machine – one for each side of the table?
Thanks in advance.
Alan.
