Boxford metric lead screw fitted to imperial lathe?
Home Forums Manual machine tools Boxford metric lead screw fitted to imperial lathe?
Viewing 5 posts - 51 through 55 (of 55 total)
  • #435345
    Bazyle
      @bazyle
      I think from MG's earlier link that Holzapffel had not originally used change gears but used a pattern thread and follower to copy threads which was and still is used most recently on the little unimat lathes. Those original threads would have been struck by eye. It was common practice for brass turners, of candlesticks etc to just make threads by hand and eye as a very loose fit was adequate for the work in question. Likewise for threads in wood.
      You can see that the half inch thread for example was trying to be 13tpi (still used today) and so 1in roughly half that. The guy who made the first pattern did incredibly well to get it that close.
      It was only years later that some awkward SOB insisted on it being dead accurately repeatable so they had to measure the reference masters and work out how to make them on a precision lathe.
        Posted by Hopper on 30/10/2019 23:07:03:
        There must have been some reason Holtzapffel settled on the TPIs that he did. Could it be as simple as that was the resulting thread when using a gear train of a limited number of standard sized change gears? So the resulting TPI was complex but the setting up of the lathe to cut it was simple?
        As Bazyle has correctly noted; and as per my previous ‘just in time’ edit [*]. The original threads, contrived by John Jacob Holtzapffel, pre-date the leadscrew version of the lathe. … But yes, your underlying logic is reasonable.
        [*] repeated for convenient reference:
        http://ftp.sizes.com/tools/thread_holzapffel.htm
        Edited By Michael Gilligan on 31/10/2019 05:19:13
        #435381
          For anyone interested in the Holtzapffel digression:
          Vol. II of ‘Turning and Mechanical Manipulation’ is available for download here: **LINK**
          https://ia802900.us.archive.org/22/items/pli.kerala.rare.6416/pli.kerala.rare.6416.pdf
          … and, quoting Charles Holtzapffel:
          Between the years 1794-1800, the author's father made a few varieties of taps, dies, hobs, and screw tools, after the modes explained at pages 635 and 636
          Cupboard
            @cupboard
            Just to close this because the problem is now completely solved. Skip to the last paragraph if you don't want to read the process.
            I made a mistake in my initial assessment. The lathe was cutting incorrectly but not for the reasons I thought. I purchased a thread pitch gauge and made some more careful measurements and the leadscrew is genuinely imperial which is, I guess, good.
            Using some information from this thread I made a giant spreadsheet with all the various gear ratios, and what pitches each setting would create. I then cut a full range of A, B, C, D, E and 1, 2, 3, …. 8. From that I determined that the ratios between each was correct – so A-B halved the pitch, C-D halved, etc. 1-2 made the equivalent ratio of 8-9 but actually did more like 8.5 to 9.5. Based with that information, I was fairly confident there wasn't anything horrifically wrong with the gearbox.
            I checked all the gears in the train under the left hand cover and they all matched what they said they should be, despite the lathe behaving as if the 56 tooth gear was actually a 60 tooth gear (if you put 60 teeth in the spreadsheet, the numbers matched the measurements).
            I then took the gearbox off, checked all the gears that transferred drive across the gearbox matched, etc. which they did.
            Whilst doing that, I noticed that there was a non-original looking spring washer and spacer washer holding the leadscrew drive gear on. For some reason, that gear had been put on backwards and with a very small tweak from the spacing washer it will mesh with the incorrect gear. It, as it turns out, is supposed to mesh with the final gear (gear 8 under the right hand lever) and it had been put together meshing with the penultimate one, gear 7. That threw the overall ratio out slightly, leading to my issues. I've now flipped the gear round (there's a spacer on one side of it), removed the extraneous hardware and it meshes perfectly with the rest of the gearbox and give the correct ratios.
            Once again thank you for all the helpful advice, numbers and support. It gave me enough of an understanding to work out the problem and fix it. Now I have a properly working imperial lathe, I just have to metrify it which is much less daunting with everything as standard!
            #436861
            Brian Wood
              @brianwood45127
              Hello again Cupboard,
              How satisfactory to hear at last the full story. I don't think it would have been possible for anyone here to guess at the way the drive was coupled to the leadscrew; no wonder the results were odd and confusing. Thank you for completing the saga
              I am reminded of one query we in the forum were able to solve 'remotely'. for a posting some time ago. It all boiled down to him using a change wheel of 54 teeth that had been incorrectly stamped as 45 teeth and only by suggesting he actually counted everything was the truth of that situation found
