Hello all,
I have been rooting around some of the threads relating to boilers on this site. This has led to a number of questions. I don't want to hijack someone else's thread so I thought I'd start a fresh one.
First off, stainless steel. There seems to be an almost pathological fear of this, and I can understand to a certain extent as it seems that austenitic is prone to stress corrosion cracking in the presence of water and heat. Fair enough.
Ok, so what about duplex stainless? Apparently a boiler has been made in this in Australia. It seems to me also that ferritic stainless might be a contender.
Regarding fabrication, I have read somewhere that if a boiler is produced by welding, i.e. TIG, the welder does not have to be coded, but can submit test pieces to prove competency. So the welder has to be competent, but not neccesarily coded. Is this correct?
In terms of TIG welding a copper boiler, I'm thinking that OFHC copper could be used with a moderate preheat, (depending on thickness) then a filler containing silicon (SIF do one think it is called sifcopper). Also helium might be useful instead of argon. Alternatively instead of the preheat one could tack at much higher current to get some heat into the joint, then proceed as normal. I've done that with aluminium before.
Just throwing some musings out there. Interested to hear the thoughts they provoke.
