Best place for offcuts
Home Forums General Questions Best place for offcuts
  • #229026
    Kit White 1
      @kitwhite1
      As per title really, teaching myself to use a lathe and need a small number of approximately 6" max. lengths of diameters up to 3", just for practicing. What's the cheapest place to get this sort of thing? Anywhere sell offcuts just as general "offcuts"?
      Kit White 1
        @kitwhite1
        #229028
        Ian Parkin
          @ianparkin39383
          Where are you?
          My local steel stockholder has bins of ends
          and very cheap
          but not for posting
          #229030
          duncan webster 1
            @duncanwebster1
            If you're just starting out you would be best to get hold of steel of known properties. EN1a machines very well indeed, some of the stuff I've picked up over the years has been awful. Doesn't mean you can't use offcuts, just try to find out what it is.
            #229033
            Kit White 1
              @kitwhite1
              May try the local stockholders then, if I can verify the properties of it first.
              Also, what is the approximate maximum size a 6" 4 jaw independent chuck will safely hold?
              #229051
                Stockholders should know exactly what every offcut is.
                Hollowpoint
                  @hollowpoint
                  Find a freindly scrapyard! They often have waste coming in from engineering company's. You can pick out some of the marked or stamped pieces if you wanna know what grades you're turning. They usually charge little over scrap price.
                  Edited By Hollowpoint on 08/03/2016 21:04:09
                  #229092
                  peak4
                    @peak4
                    Posted by Ian Parkin on 08/03/2016 16:54:15:
                    Where are you?
                    and very cheap
                    but not for posting
                    Ian, am I correct in thinking you're in the Sheffield area?
                    if so, would you mind PMing me which stockholder you use.
                    Thanks
                    Bill
                    #229117
                    Ian Parkin
                      @ianparkin39383
                      Bill
                      I use wd steels for mild steels in bar and flat
                      I use phoenix steels for silversteel and GFS
                      #229214
                      peak4
                        @peak4
                        Posted by Ian Parkin on 09/03/2016 09:13:04:
                        Bill
                        Thanks Ian, I'll add to your list with "AMB Stainless" for alloy bar, and surprisingly stainless too. (not scrap box stuff, but happy to cut short lengths to order for personal visitors.)
