alluminium extrusion
Home Forums Materials alluminium extrusion
  • #411292
    sparky mike
      @sparkymike
      I am looking for some lengths of alloy channel approx 3/8" deep X 1/4" wide in 18 gauge or thinner. Channel has to have a rounded bottom, with square sides.
      Mike.
      sparky mike
        @sparkymike
        #411293
        sparky mike
          @sparkymike
          #411301
          Ian McVickers
            @ianmcvickers56553
            FHBrundle.co.uk have steel and stainless steel u profile if you cant find any alloy stuff. Its under Edging sections in their shop.
            #411310
            sparky mike
              @sparkymike
              It has to be alloy, as it will be fitted round four sides of a rounded corner panel edge.
              Mike.
              #411344
              Jeff Dayman
                @jeffdayman43397
                You might be able to find oval tubing extrusion more easily, then cut it in half to get your channels. Lots of oval tube extrusions on Asian websites.
                #411362
                sparky mike
                  @sparkymike
                  I will probably have to turn up a couple of rolls, male and female section, for my sheet metal swaging jenny. That may well work if I can pass the strip of alloy through the rollers dead center. Worth a try.
                  Mike.
                Home Forums Materials Topics
