Posted by Michael Edwards 1 on 03/08/2013 08:15:49:
Hi both thanks for the reply. I have chamfer on bar. Also putting tail stock up against die holder but still no joy. I have got to the stage that when applying pressure with the tail stock. I can put the lathe on jog and actually stop the lathe with the amount of pressure I had put on it. It must be cheap metric dies I have. They don't have a split in them.
Have you tried screwing a standard M6 bolt into the 'die' you have (just to check its not a left hand one! Dont laugh it does happen.
I recently reground a good quality, brand new 15mm drill that would not even open up a 12mm hole in aluminium. It had been sharpened as a left hand drill!
Totally unrelated but many years ago I spent hours hours trying to diagnose a fault on a precision AC millivoltmeter I was making and eventually found a IN4148 diode (a very common component) which had its marking band at the wrong end. During fault finding I had even disconnected components and checked with a meter that it was a working diode.
Ian P
Edit, I should have said M8
Also, I think it unlikely you will end up with a good/nice thread using a solid die, my understanding is that they are mostly used for cleaning up damaged threads.
I recently
Edited By Ian Phillips on 03/08/2013 09:04:46
