Adding a quill lock to a drill press
Home Forums Manual machine tools Adding a quill lock to a drill press
Viewing 3 posts - 26 through 28 (of 28 total)
  • #808765
    beeza650
      @beeza650
      On Nicholas Farr Said:
      Hi, I don’t know about other makes, but with my Clarke floor standing one, I can hold the quill down using the depth gauge by swivelling it the opposite way round, for removing the chuck or tapered drills for instance.
      Clarke Drill
      Regards Nick.
      Doh!…yes. ermm well, in my defense it took a lot of replies to get the right answer. Thanks 🙂
      John Purdy
        @johnpurdy78347
        Yes, that works on mine also so would probably work on yours also beeza. But it only stops the quill from retracting, it can still move down. It doesn’t actually lock the spindle from moving.
        Nicholas Farr
          @nicholasfarr14254
          Hi, it’s also handy for when you use a pilot drill for many holes, and then use a larger drill. By setting  the height of the table to the larger drill, you can then set the depth gauge as a back stop for the pilot drill, so you don’t have to wind the quill down a long distance for each of the holes you need to pilot drill, and then release it when you are ready to enlarge the holes.
          Regards Nick.
