Reply To: Belt and Disc Sander
Home Forums Workshop Tools and Tooling Belt and Disc Sander Reply To: Belt and Disc Sander
#318548
Clive Foster
    @clivefoster55965
    Try a decent belt first then consider replacing the machine.
    I swopped my Draper belt & disk sander, about 1/4 decent so it did an acceptable job, for a RJH Antelope band-facer which is much, much better performer than I'd anticipated. Proper pro ones are better still but this beast runs them fairly close. Objectively I paid far too much money for it and its Gryphon grinder mate but both have effective built in vacuum dust collection stands and, after 30 odd years, all the sweeping, hoovering, wiping and complaining about dust getting everywhere was getting a bit old. £900 worth of old in this case!
    The uber cheap belt and disk sanders can be awful. Wide tolerances and "Customer paid, passed QC" issues. Depends on your luck. Some are, accepting their inherent limitations, fine out of the box. Some need a bit of titivation and some will always be ruff as a badgers backside. Rare to find one that is irredeemable but considerable sensitivity to belt tracking adjustment is common and can test your patience. You'd have thought that the spring tension systems would have lessened the sensitivity as compared to the solid screw adjuster type but thats not been my experience. Quality belts really help here. The Draper OEM ones I got with mine usually needed a tweak at each start up and about every 15 to 30 minutes in use.
    Bargain belt multi-packs aren't good idea. The joint doesn't last forever in store and decent belts last so long that you will rarely change them. Best to get the disks when you needed them. The stickum stuff is pretty much past its sell by date after a year or so. Takes a lot longer before it really won't stick any sense but everything works better with a properly stuck on disk.
    I found a cheap Picador plain bearing spindle linisher to work much better than it had any right to do. Objectively a rather better performer overall than the Draper belt and disk one that replaced it. But I needed the disk and bigger belt. Soon learnt the little tricks and techniques to get the best out of the Draper. The Draper was a perfectly adequate tool but I was always aware of working around its limitations.
    Clive.
    Edited By Clive Foster on 25/09/2017 11:13:44
