How to determine the spec of a pinion gear wheel
Home Forums Beginners questions How to determine the spec of a pinion gear wheel
  • #7836
    Steve Withnell
      @stevewithnell34426
      #209169
      Steve Withnell
        @stevewithnell34426
        I managed to destroy my paper shredder yesterday, it wasn't man enough to eat a bank book…the pinion on the motor shaft disintegrated.
        It will be really difficult/impossible to buy a new one, but should be easy to make one – it's about 15 straight teeth and about 1/2 inch overall diameter.
        If I stick all the bits back together so I can measure it properly, how do I determine if it's Module or spec'd in DP and then measure the key characteristics? I think I can count the number of teeth, pretty accurately
        Fingers crossed it might just drop in with the job lot of cutters I bought a couple of years ago.
        Steve
        #209173
          Steve,
          Count the teeth, and add two
          Measure the Outside Diameter, in inches
          DP is one over t'other
          If it doesn't compute to nice number, try converting to Module.
          … Sorry: of out now, more tonight if someone hasn't already explained it better.
          Roderick Jenkins
            @roderickjenkins93242
            As MG says. Metric module is 25.4 divided by DP.
            Rod
            #209197
              Unlikely to be DP, more likely MOD
              15T 0.75Mod is 12.75mm OD which is "about 1/2" "
              Edited By JasonB on 25/10/2015 13:46:09
              #209200
              John Stevenson 1
                @johnstevenson1
                Very close to 32DP which will be good enough for a paper shredder.
                #209225
                duncan webster 1
                  @duncanwebster1
                  HPC list 15t 0.75 module, for about £10. I daresay if you send them the bits they will advise
                  #209291
                  Gordon W
                    @gordonw
                    Unless you really want to make a gear wheel just buy a new one, shredder that is. Strip the old one for useful bits. Mine 's just gone in sympathy with you.
                    #209361
                    Steve Withnell
                      @stevewithnell34426
                      Looks like I can neither measure nor count…
                      I took a look at the HPC catalogue and tried to match it to their gears, best fit is Module 2, 24mm(!) and 9 teeth (!!)
                      When I look at cutter numbers, stock cutters only go down to 12-13 teeth – so 9 teeth sounds like not that easy at all – or is there a trick?  Otherwise it's a salvage project,  rather than a repair.
                      Steve
                      Edited By Steve Withnell on 26/10/2015 18:00:25
                      #209363
                        Work out the DP/mod from the gear it meshes with, it will be bigger with more teeth and therefore easier to measure accurately, also the larger gear is less likely to have a modified profile.
                        Yes, file up a single point cutter to be a good fit in between two teeth of the broken gear, and cut about 4-5 thou deep.
                          Posted by Steve Withnell on 25/10/2015 10:06:43:
                          If I stick all the bits back together so I can measure it properly …
                          Steve,
                          Going back to your opening post ^^^
                          If you have put enough of the bits together … please take a photo, or put it on a flatbed scanner, so that we can see.
                          Based on your original figures of 15 teeth and 1/2" OD …
                          17/0.5 = 34 DP … but pinions are often cut 'wrong' to get the working clearance: My guess is that the matching gear will be 32 DP, or Module 0.8
                            dont know … of course; if it is really 24mm OD and has 9 teeth, you can safely ignore my last night's calculation !!
