Chamfering on the lathe
Home › Forums › Beginners questions › Chamfering on the lathe
Viewing 25 posts - 1 through 25 (of 33 total)
  • #153275
    Hugh Gilhespie
      @hughgilhespie56163
      I would be very interested to know how other forumites set up for chamfering on the lathe. I find it a bit of a struggle and it usually takes me a couple of tries until I have a set up that lets me access the edge of the piece I am turning without either hitting the chuck or running out of travel on the cross slide or top slide. I am using a Cochester Student lathe with a QCTP and the method that I usually use is to set the top slide over to 45 degrees with the tool post pointing towards the chuck, fit a tool with a 9 mm circular insert and chamfer on the far side of the piece with the lathe running in reverse, using the top slide to move the tool past the edge of the work and backing the cross slide until the tool starts to contact the work. I can't help feeling there must be an easier way so all suggestions gratefully received.
      Hugh
      #7169
      Hugh Gilhespie
        @hughgilhespie56163
        #153287
          If its a small chamfer say below 2mm long then I have a tool ground with two 45deg faces which will do for both internal and external chamfers. No need to move toolposts ot topslides about just change tool holders and away you go.
          If its much wider than that then if I'll move the topslide handle away from me to 45deg and use a right hand tool.
          #153289
          Les Jones 1
            @lesjones1
            Hi Hugh,
            Nice to see you back on the forum after a long time. That method of chamfering seems perfectly sensible to me. How is your stepper controller project for driving the cross feed going ?
            Les.
            #153294
            Clive Foster
              @clivefoster55965
              # 2 for Jasons method. Flat top tool does fine.
              I too have a QC post (Dickson) and the tool gets switched from one end of the holder to t'other on a regular basis depending on whether endwise, as in Jasons picture, or straight in does best. On my Smart & Brown 1024 chamfers up to 1/2" long are feasible with such tooling although with the larger ones its better if you have something roughly right cut stepwise or left from a roughing tool to start with so the chamfer tool is cleaning up rather than cutting it all. Coolant / cutting oil helps too. I use a Bjur Spraymist system.
              Entierly agree about the difficulties of setting up to cut relatively long chamfers. Big problem I find is the sheer bulk of the QCTP which can seriosuly get in the way.
              #153301
              Hugh Gilhespie
                @hughgilhespie56163
                Jason – I like your method. I have tried this with an old carbide insert with a 90 degree point – i.e. two faces at 45 degrees but it wasn't terribly successful, just not sharp enough away from the tip I think. I am STILL working on the Worden tool grinder I started 4 years ago and hopefully when I finish it I will be able to grind form tools including one like the one you are using.
                Les – I moved house in late spring last year and have only just got a workshop back so everything has been on hold for about 18 months. I got as far as completing all the electrical side of my cross slide drive project but stalled on the – in theory – simpler stuff to design and make the mechanical components to drive the cross slide handle. It is on the ever growing Things To Do list and I am motivated by having a lovely new workshop – ex stone barn but now fully insulated and with a new roof, concrete floor, etc that is a pleasure to work in.
                Hugh
                #153304
                steamdave
                  @steamdave
                  I can't disagree with the short chamfer methods suggested.
                  For a long internal chamfer, why not use a boring bar with the toolpost set round to the required angle? Just feed in with the topslide. Use the X axis for the depth of feed.
                  For an outside chamfer, use any toolbit that has a straight edge with the toolpost swung round to the required angle and just feed in. Jason's set up for the external chamfer will avoid hitting the wrong bits of the lathe.
                  Am I missing something?
                  The Emerald Isle
                  #153311
                  John Haine
                    @johnhaine32865
                    I just dial it in as a short taper at 45 degrees using a cnc wizard in Mach3 and set it off…
                    #153361
                    jason udall
                      @jasonudall57142
                      It seems that the use of simple form tools is out of favour. …
                      #153362
                      jason udall
                        @jasonudall57142
                        Or even gravers
                        #153366
                          Posted by jason udall on 24/05/2014 11:29:10:
                          Is that not what I have shown and several other members shown a preferance for. Also same thing as JS posted on his sharpning thread.
                          Just as quick to put the above tool in the QCTP than set up a rest and use a graver though I do have a fine file that I keep on the lathe for knocking off corners/burrs and have the end ground like a scraper that tidies internal holes.
                          J
                          #153368
                          Ian S C
                            @iansc
                            For the work I do on agricultural machinery, I use a long angle lathe file(no one mentions those things), it works well whether it's a small chamfer, or even if quite a bit of metal has to come off, ie., a radius on the end of a shaft.
                            Ian S C
                            #153371
                              Ian, have you a picture of said file not heard of a "long angle lathe file" before.
                              J
                              #153374
                              julian atkins
                                @julianatkins58923
                                files and clockmaker's gravel for me too!
                                cheers,
                                julian
                                #153381
                                colin hawes
                                  @colinhawes85982
                                  You need to make sure the tool has enough rake to avoid rubbing on its lower edge when chamfering a bore or for unimportant work set it well above centre height. Colin
                                  #153393
                                    I often use a parting tool with the toolpost turned at 45 degrees. Unlike many tool shapes the cutting edge is flat so you get a true surface. It's much quicker than turning the topslide.
                                    Clive Foster
                                      @clivefoster55965
                                      Posted by Neil Wyatt on 24/05/2014 15:11:55:
                                      Although this can work well turning the tool post and, for that matter the top slide, is a thing to be avoided if at all possible. Yes it does help you get more use out of a tool by pressing it into service to do jobs it wasn't specifically designed for but at the cost of needing to reset back to for normal afterwards. Possibly an acceptable process if you use a rear toolpost for parting or if you have a good indexing base for your four way or QC set-up so as to get things back to parallel automatically. Setting things exactly at 90° for parting off is essentially impossible mid-job with work in progress mounted up unless you have some clever way of gauging things.
                                      Accurate angles belong on the tool not the mounting. The extra cost and mostly one time trouble of arranging a set of tools such that you don't have to routinely shift top slide and/or tool post angles is well repaid by the time saved and better cutting performance got from optimising around one set of working conditions. Shop time is a precious, limited, resource not to be wasted by repeated resetting.
                                      #153401
                                      jason udall
                                        @jasonudall57142
                                        Jason B..indeed..never said it wasn’t. I am trying to agree with you..
                                        It just seemed after your initial post others seemed to “look” for complex ways of doing what if normaly a simple job.
                                        To machine a specific camfer feature or even a large/long one ..yes a different approach but simple corner breaks or radi…..
                                        Well you get the picture..
                                        #153407
                                        Colin Heseltine
                                          @colinheseltine48622
                                          Hugh,
                                          I cant help with your chamfering issue but am interested in which QCTP you are using. I also have a Colchester Student lathe (squarehead) and am looking to obtain a QCTP for this lathe rather than use the not very nice 4 way toolpost.
                                          Thanks,
                                          Colin
                                          #153435
                                            I do, it's as repeatable as swapping toolholders and changing back again.
                                            Hugh Gilhespie
                                              @hughgilhespie56163
                                              Colin,
                                              The QCTP came with the lathe when I bought it. It is a Dickson type and I believe it is size T2. It is a pleasure to use and particularly as I was lucky enough to buy a goodly number of tool holders from an ex-employee of Colchester lathes along with some other goodies, including the reat tool post that I use for parting off with an upside down tool.
                                              I will try and post a picture of the QCTP.
                                              Regards, Hugh
                                              #153437
                                                Ian,
                                                So, it seems there are files designed for safer use on the lathe:
                                                "Designed for smooth finish lathe work on either hard or soft metals, this file has the teeth cut on a long angle. Both edges safe (uncut) to permit working next to a shoulder without injury to it. Also used for finish filing of aluminum. Files are single cut. Opposed direction of the cut on the front and back side forces the file away from the chuck during lathe work, improving safety."
                                                Hugh Gilhespie
                                                  @hughgilhespie56163
                                                  Colin,
                                                  This is the toolpost on my Student
                                                  #153450
                                                  speelwerk
                                                    @speelwerk
                                                    Using a file for making a chamfer works fine, but do use a file which has a grip on the end, it is much safer. Niko.
                                                    #153469
                                                    “Bill Hancox”
                                                      @billhancox
                                                      Further to Neill's comment
                                                      The link below refers to using standard files which normally have a cutting angle of 65 Deg. Skewing the nose of the file 10 Deg to the right (handle 10 Deg to the left) will replicate the longer cutting angle and smooth action of a lathe file. The shortcoming of a this method is that it cannot be utilized right up to a shoulder while the file is angled. The technique works great for straight turned work. Of course chalking the file and keeping it clean during use is one key to smooth finishes and longer file life. When the Canadian Army started to move from chalkboards to dry erase marker boards, many boxes of chalk that ended up in the dust bin mysteriously migrated to my shop. I also have some of the jumbo sticks of pavement chalk that I share with my grandchildren when they want to mark up my driveway, **LINK**
                                                      Cheers
