pickling
pickling
Home Forums Beginners questions pickling
  • #4675
    david simmo
      @davidsimmo
      #41519
      david simmo
        @davidsimmo
          hi me again is citric acid ok for pickling copper boilers becouse it safer to use
          but soak for longer and anyboby know where I con get a container whith lid I have spent a hour or to on the computer buy Iam abit old fashion just learing!!
                  thanksdave  ps where spell chech on site??
        #41523
        Richmond
          @richmond
          Hi David, and welcome to the site
          Citric acid is fine for pickling boilers.
          As to containers you should be able to get that kind of stuff from a brewers merchants.
          Spell checking is something that will be looked at in the future.
          Rgds
          Richmond
          #41532
          Ian Lee 4
            @ianlee4
            I used a couple of 25 litre plastic brewing buckets on for the citric solution the other for water to clean it off  after pickling, I’ve seen these buckets in some garden centres also try a couple of plastic dustbins with the lids having a hold down clip on them, a lot of horse tack shops sell these as they use them for feed bins and they are not that expensive
            Edited By Ian Lee on 19/05/2009 21:58:58
            #41546
            david simmo
              @davidsimmo
               thanks richmond,ian sounds good to me thanks again dave
              #41547
              Circlip
                @circlip
                Never heard of “Tupperware” David??? But if you nick one from SWTSMBO, be prepared to Ruuuuuuuuuuuun. ‘Salso a good idea to CLEARLY mark the container with a Skull and Crossbones (Well, you don’t want your boiler covered in Icing Sugar do you???) The Citric ain’t poisonous but the dissolved Copper in it gives it a “Distinct” taste.
                     Regards  Ian
                  PS, practice spullin
                #42517
                Chris
                  @chris16039
                  If you live in a rural area you may have noticed rectangular plastic buckets in fields. They are mineral suppliment blocks for livestock. Very strong plastic, snap on lid and being about 16 inches long by nine wide and nine deep are a good shape for our purpose. farmers usually have sheds ful of empty ones.
                  Chris.
                  #42599
                  Redpiperbob
                    @redpiperbob16487
                    Hi dave
                    Just came across this thread
                    I use the following programme for my spell checking
                    just download and install it.
                    Then Right click anywhere on your post and click check spelling.
                    Before you use it for the first time make sure to click on iespell options then language and dictionaries and choose (English UK)
                    good luck
                    Bob
