Early myford super Seven parts identify plz
Home Forums General Questions Early myford super Seven parts identify plz
Viewing 25 posts - 1 through 25 (of 30 total)
  • #328875
    Piero Franchi
      @pierofranchi37209
      Hi Guys
      Looking for some help with sorting out what I was given (spare/accessory parts) with My early super 7
      not long ago finished a full restoration on this lathe,
      I was given a load of other stuff with my myford, that I had aside up un till now, kept separate from my lathe, only to not confuse me as I was doing the rebuild,
      I have lots of parts that came with the lathe but this is the stuff I cant work out what it does or where it goes,
      so over to you for your help please.
      photos are in my blog.
      Top left gear is a 30T didn't write down the outer dia, its 1/2 thick
      the other three items appear to be a set, only the shaft looks a little on the short side
      the two gears are 30t and a 20t
      shaft is 6/8 long (portion gears could run on)
      Edited By Piero Franchi on 24/11/2017 14:32:49
      Piero Franchi
        @pierofranchi37209
        spare parts
        #329066
        ega
          @ega
          Piero Franchi:
          Congratulations on your "full restoration" – I assume this is not one of those situations where you have left over parts and don't know where they should go!
          I looked at your "blog" [=album]. The individual gears look like Myford gears but it would help to know the diametral pitch and pressure angle. That said, if your gear train and/or gear box are working properly you probably needn't worry about the identity of the mystery parts.
          This post will remind more knowledgeable Super 7 owners of your question and I hope your curiosity is satisfied in due course.
          #329113
          Piero Franchi
            @pierofranchi37209
            No, As I said in my post, I was very care full to keep the lathe parts well away from the accessories that came with the lathe.
            The lathe went back together with out a lost/missing or extra parts without a home.
            The bits in the photos where extra items i am now trying to identify
            I have found in the myford website a part number for one of the gears, HT45 Tumbler sleeve gear assembly 10351
            the tumbler gear that was fitted to my super 7 when I picked it up was a one piece item, this is a two piece item.
            I am guessing this is so you can have a different ratio with out changing the whole thing
            #329115
            bricky
              @bricky
              They look like they fit on the change wheel banjo as that is a spacing washer so that two gears don't bind when engaged.
              Frank
              #329124
              Piero Franchi
                @pierofranchi37209
                I am new to myfords, Might you know of the myford part number plz bricky
                #329140
                bricky
                  @bricky
                  Sorry I can't help you there but try the square section on the banjo and that might give you a clue that it is from there.
                  Frank
                  #329164
                  peak4
                    @peak4
                    The first photo in your set shows the first driver set of the leadscrew chain. The following comments assume a lathe doesn't have a gearbox fitted.
                    Following typing the rest of this diatribe I've re-visited your photos and realised that you must have a gearbox fitted as you've got a copy of its manual.
                    The gear which is fixed to the bronze bush engages with the tumbler gears for forward/reverse drive of the leadscrew.
                    Onto this you fit the first drive gear to start the screwcutting/fine feed change gears in motion (Most commonly a 20 tooth gear for imperial, or 21 tooth for metric threads, on a non-gearbox lathe).
                    You should have one on your lathe now assuming the leadscrew/gearbox turns when you operate the lathe.
                    N.B. If you have a fixed ratio dual sized gear in place at the moment, it's most likely the one designed for an even finer feed of the leadscrew, which will give you all the wrong pitches if you try screwcutting. (this is available as an optional extra)
                    The bolt with a flat section below the head, is to set up another pair of gears in the drive chain, not for the gear with the attached keyed stub. The squared off bit saves it rotation on the banjo. There should also be a bronze "Top Hat" bush which runs on this special bolt, which I can see in your photo, and in turn, a tube with an external key which runs on the top hat.
                    This allows a pair of gears to be keyed together, separated by that little washer with a slot in it. The whole assembly then sits on the banjo to the left of the headstock, and allows an intermediate pair of gears in the drive chain.
                    I hope this reads OK as it's not easy to describe without pictures.
                    Further edit of my post; I's say these are probably surplus to your immediate requirements, subject to the warning I gave above regarding the gear just below the Tufnol tumber gears.
                    Assuming you will at some point need to cut metric threads, it is possible on an imperial gearbox lathe by changing the initial drive gear in the chain. i.e. the one that sits on that keyed boss in your first photo.
                    Bill
                    Edited By peak4 on 25/11/2017 21:49:31
                    Edited By peak4 on 25/11/2017 22:13:57
                    #329167
                    peak4
                      @peak4
                      N.B. I wasn't quick enough editing my previous post.
                      Following on from where I typed
                      I should have added, on your gearbox equipped lathe the drive gear should probably be a 24/30 tooth combination.
                      There might also be a chart inside the door giving alternatives to the 24 tooth gear for cutting metric threads.
                      Just got back in the edit time to add the link to Tony's Lathe resource for Myfords.
                      Bill
                      Edited By peak4 on 25/11/2017 22:22:33
                      #329188
                      Piero Franchi
                        @pierofranchi37209
                        Many kind thanks Peak4
                        you have explained that very well, and it has given me some direction and possible clues to my lathes history.
                        I do not know if this lathe came fitted new from the factory with its gearbox, it could have been an added extra that might explain the first gear in my photo, the one that you have said is the first driver set of the leadscrew chain.
                        My super7 is a non carriage power feed,
                        its possible the previous owner fitted the super fine fixed tumbler gear in place of the two part 30t to 20t (as per my photo, in order to give him a fine feed so he could power the carriage with the gearbox and use it for cutting ????
                        just a guess mind.
                        I know know a little more about my lathe, and will be on the look out for that brass top hat you spoke off, if only so it does not get chucked out.
                        Is it ok to leave the super fine ratio tumbler gear in place and use the gearbox to power the carriage (on the final cut) to get a more even cut ?????
                        #329217
                        peak4
                          @peak4
                          Piero, I may have misled you regarding tooth numbers on the initial drive gear; the one that is just below the tumblers. Unfortunately I can't edit my earlier posts
                          I've just been looking at your other albums, and seen your photos relating to a very nice re-build.
                          I'm no Myford expert by any means, though I've owned a tatty Super 7 for about 30 years. Mine, though old is newer than yours, and is fitted with changewheels, rather than a gearbox.
                          I also have a Warco copy of a Super 7 with gearbox, which seems to be a copy of a later variant of the super 7, with power x feed.
                          Going by the photos on Tony's web site, I think your lathe is one of the early ones, looking at the cap above the spindle, perhaps fitted with the early screw cutting gearbox, so the drive ratios may be different to mine, but still achieve the same final gearing at the output side. Check though the various pages he hosts and check for yourself.
                          I don't want to deep link to photos on his web site, but of you follow the link to an ML7 Photo Essay and scroll down to where the left hand gear cover is open, you can count the teeth on the gear on the tumbler stud. That photo shows 20 teeth to drive the gearbox on that ML7. My Warco copy has a 24 tooth drive gear on there, similar to some of the other genuine Myford photos on the same site.
                          If you have a look on Myford's web site, and type "Fine Feed" into the search box, you will see the one piece tumbler drive gear; there's a variety of pitches at the large end, to suit the application, but all are 12 tooth at the small end; these would normally be used to provide a finer feed on a changewheel lathe like my genuine Super 7. I don't believe that any of the gearboxes used a 12 tooth drive gear on the tumbler stud.
                          Just an offbeat thought, if you were to select 8 TPI on the gearbox (the same as the leadscrew) one complete turn of the chuck should result in one complete turn of the leadscrew if the drive gear is the correct one.
                          Bill
                          #329267
                          Piero Franchi
                            @pierofranchi37209
                            Here,s a question for everyone
                            If like me you have a screw cutting gearbox, are the full set of metric gears off any use to you????
                            #329396
                            HughE
                              @hughe
                              Hi Piero,
                              You have the same model S7 as me. It looks like the parts are from the metric conversion banjo assembly.
                              I have a Operation, Installation, maintenance and pictorial parts list manual. If you are interested I could send you a scanned copy. PM me if interested.
                              Hugh
                              #329411
                              DMR
                                @dmr
                                Hi Piero,
                                You have identified the tumbler stud sleeve gear 10351. This replaces the 12 tooth ganged tumbler stud that is fitted on your machine as you seem to have worked out. On a more modern machine your 12T would be a 24T and the 10351 part would be a standard part. Your gearbox needs the 12T you have to operate correctly. Its a left over from the ML7 days. The washer in your picture will be 50 thou thick and along with the shaft piece are part of the metric conversion kit, which must have existed with your lathe at one time along with a set of gears which DO NOT form part of the current metric conversion set as the external gearing on your early gearbox is different.
                                You have previously said that you want to work in imperial, not metric. You can cut short metric and BA thread approximations with what you have by fitting the 10351 plus 20T, 21T, 33T or 34T (mostly the 33 & 34) onto the 10351 part. If you want to cut more accurate metric threads, then you need the metric conversion set, but you would have to supplement the supplied cogs in that set to cut all metric threads on your early gearbox.
                                Various mails on here talk about rough Myford metric screwcutting using the gearbox. I have deleted our previous correspondence and repeat my e-mail in a PM if all is not clear now.
                                Dennis
                                Edited By DMR on 27/11/2017 16:23:23
                                Edited By DMR on 27/11/2017 16:24:19
                                #329414
                                DMR
                                  @dmr
                                  repeat post
                                  Edited By DMR on 27/11/2017 16:21:40
                                  #329423
                                  Simon Williams 3
                                    @simonwilliams3
                                    Posted by DMR on 27/11/2017 16:13:03:
                                    Hi Piero,
                                    Dennis
                                    Couple of things spring to mind:
                                    If I've understood that the gearbox train input gear is 12 T mot 24, then this is the old gearbox and the 20, 24, 33, 34 gears are a red herring. There is much buried in the archive to explain further, for example **LINK**
                                    Also the idea that the 33 or 34 t gears give a "rough" approximation to a true metric conversion is wrong. They give a very close, useful method of getting to the "near enough" answer.
                                    If the OP wants to adapt his lathe for metric threads and it is the old half speed g'box he needs the 17T or 16-1/2 T gears of the thread above.
                                    Rgds Simon
                                    #329455
                                    DMR
                                      @dmr
                                      Oops,
                                      Quite right Simon, Old age strikes again. I only formulated my own "metric roughs' tables for my newer machine. I must get round to doing the same table for my older one. Divide by 2 with quirks. I prefer my threads to be right, so I've never actually used the option.
                                      Dennis
                                      #329490
                                      Piero Franchi
                                        @pierofranchi37209
                                        All It was, was as I had now come to the end of my rebuild, I was trying to identify other parts that were given to me as spares along with the lathe. As per my photos in my blog.
                                        Just to clarify, Yes this is the early Super7.
                                        No I don't especially want to cut metric threads, I just want to know what I have in turms of accessory
                                        I was given a set of metric gears with my lathe, all boxed and most of them still have the wax coating on them,
                                        I assume that they are for the Early super 7
                                        Edited By Piero Franchi on 28/11/2017 08:47:12
                                        Edited By Piero Franchi on 28/11/2017 08:47:35
                                        #329500
                                        Simon Williams 3
                                          @simonwilliams3
                                          Hi Piero, yes I certainly believe this is a Mk 1 Super 7, it has the oil drip bath for the front bearing the same as mine.
                                          Mine is dated 1953 if I remember right.
                                          Inside the gear gover ( which isn't original, but is much the same date and is the early gear box) is the following label:
                                          This seems to be different from the "Metric conversion kit" of the later models with the gearbox driven by a 24T gear on the mandrel. For the sake of completeness here is a picture of the corresponding label for the later gearbox:
                                          HTH
                                          Simon
                                          #329521
                                          Piero Franchi
                                            @pierofranchi37209
                                            Hi Simon (and others)
                                            Thanks for the photos,
                                            I too have this on the inside of my door.
                                            Having never changed any thing from the standard form my myford arrived to me, I am a little confused as to what exactly I change in order to get my desired metric ratio,s
                                            The metric box set of gears I have, is about 15 odd pieces, mostly gears. some of them rather large.
                                            where do they go ????
                                            #329553
                                            steamdave
                                              @steamdave
                                              Posted by ega on 25/11/2017 11:23:57:
                                              Piero Franchi:
                                              As an aside… The engineers on board would sometimes play tricks on their mates when an engine overhaul was being undertaken. The usual thing was to hide a couple of bolts before rebuild, but an evil one would throw in an extra bolt, causing a bit of head scratching for a while.
                                              The Emerald Isle
                                              #329566
                                              Simon Williams 3
                                                @simonwilliams3
                                                Hi Piero, I think the best answer to your question about where do the bits fit is to suggest you need a copy of Brian Wood's book, Gearing of Lathes for Screwcutting, which gives chapter and verse on the subject. ARC have copies, and so did Amazon the last time I looked.
                                                Essentially the gear train that carries the drive from the lathe mandrel down to the gearbox input gear is removed, and replaced with a selection of gears of different tooth numbers, all as per the appropriate label as above.
                                                The standard banjo on which the gears are mounted isn't slotted, so this limits you to only using the original gears. To be able to use others (as per the label) you need the gears AND a different banjo. The one that Myfords sell, and which has been called the "Metric Conversion Kit", fits in place of the standard gear mounting carrier and allows change wheel trains to be built up in much the same way as you would in the old days before the quick change gearbox was invented. The difference here is that the slotted "Metric conversion kit" banjo lets you keep the quick change gearbox AND change the input ratios. That's what the labels above are showing.
                                                The other half of the metric adaptor kit is a selection of change wheels of some funny looking numbers, as detailed on the labels above. If you would like to list the wheels you've got lurking in a box we can tell you what you can do with them, and whether they belong as a set with the metric conversion kit. (And for which version of the Q/C gearbox!)
                                                Brian's book explains in more detail.
                                                Myford users being inventive so – and – so's, along came the idea of keeping the original fixed spacing gear carrier, and changing the input gear (mandrel gear) to adapt the ratio between the mandrel and the lead screw. It happens that an extremely close approximation to the "correct" ratios can be achieved for a wide range of metric pitches just with a small handful of input gears. For the later gearbox, most of the metric pitches you'd likely want are achieved with a 33T and a 34 tooth gear, mounted on the 10351 tumbler adaptor as detailed above. John Stevenson pioneered this, and the gears to do it need are available from Myford. But it doesn't work for you and me – read on.
                                                The big advantage of this technique is that you get to keep the fine feed ratios. If you fit the "metric kit" you lose the facility of the fine feed. The metric pitches you get are an approximation to the "true" metric pitches, but that's also true of the pitches you get with Myford's metric adaptor kit. Some of the approximate results are actually better than the original design, and (as Brian's book examines) you need to consider the limitations of the lathe's accuracy as well.
                                                For your lathe – and mine – this doesn't work, as the early gearbox does not have the built in 2:1 speed reduction of the later gearbox, so if you set up the gear train as for the later box you cut a thread of twice the pitch you expect.
                                                All is not lost, we know how to fix it. If you want to get involved with this we can explain further, but you really need to see Brian's pictorial explanation of what is going on first, as the adaptations to make it work with your earlier gear box assume an understanding of the overall system and also some rather creative gear cutting which John Stevenson devised.
                                                Hope this makes sense,
                                                Rgds Simon
                                                #329697
                                                DMR
                                                  @dmr
                                                  Hi Piero,
                                                  The early "Metric Conversion Set" for the gearbox you have consisted of 10 gears as follows: 20T, 30T, 35T, 40T, 44T, 45T, 52T, 55T & 2x60T. If you have these in your box then you have the early set. The pictorial supplied by Simon and which you have on your changewheel door is the correct one for your lathe, but the conversion set that you have may be a later set for the newer gearbox. As further clarification the only difference between the two sets is in the gear selections, all the other parts stayed the same.
                                                  The later set consists of 12 gears: 28T, 30T, 35T, 40T, 2x45T, 2x50T, 55T, 2x60T, 63T. With my set of later gears in its box, I have supplemented the set with additional cogs and any previous owner may have done the same or similar with the set you now have. My choice of my extra 6 cogs gives me all the options for any thread using the early gearbox.
                                                  The use of the metric quadrant is fully explained in the gearbox manual, most likely page 6, along with a pictorial of all the parts you should have in the box. The parts list also shows the Conversion set pictorial and if that fails the Myford site has it for free under gearbox. The washer and shaft in your pictures should be in the box and probably the two cogs as well if there are spaces in the cardboard cutouts for them to fit. There is nowhere in the box for the tumbler sleeve gear. Note that as already explained, the ratios in the later gearbox manual do not work on your gearbox.
                                                  As an additional note, The early "Metric Set" on the early gearbox did not give as accurate threads as the later combinations.
                                                  Hope that helps
                                                  Dennis
                                                  #329711
                                                  Piero Franchi
                                                    @pierofranchi37209
                                                    Once again many kind thanks for your help
                                                    Its probably been said before, but people with learning difficulties normally prefer to ask questions specifically to there need,
                                                    its quite a task reading a mound of stuff (if you struggle to read) in order to find that one bit of info you need.
                                                    I was born dyslexic and asking questions works better for me on the whole,
                                                    sorry to others who have read this TYPE of gearbox topic before.
                                                    If its ok, Id like to take some photos of my metric gear set and post them on my blog for you to see,
                                                    wont get that done till tomorrow now.
                                                    Once again, many kind thanks for all the input and help
                                                    O and thanks spell check LOL LOL
                                                    #330044
                                                    Piero Franchi
                                                      @pierofranchi37209
                                                      just added two photos and a description under each photo.
                                                      some gears are doubles, this can be in a different tray
                                                      As well as the banjo, the two shafts and two spacers, I have gears with teeth off
                                                      28t 28t (as in two of the same) 60t  60t (two of the same) 65t 25t 45t 63t 35t 38t 45t 50t 50t (two of the same) 55t and a lose as in not in this box set of 40t
                                                      Edited By Piero Franchi on 01/12/2017 12:17:05
