Taper Pin
Taper Pin
Home Forums General Questions Taper Pin
Viewing 25 posts - 1 through 25 (of 35 total)
  • #98398
    mick
      @mick65121
      h 012.jpgYou've never let me down so far, so here's another, doe's anyone know question.
      Doe's anyone know where I can source one taper pin 2.750'' long by 0.350 at the large end, its for a clapper box pivot pin, which has to be better that the coach bolt that was acting as a pivot when I bought it.
      Picture of the cleaned up and repaired tool slide.
      #22214
      mick
        @mick65121
        #98401
        Martin W
          @martinw
          Mick
          It may be a stupid question but why a taper pin? I would have thought that unless the taper ran through the clapper box and clapper (tool holder) then the clapper wouldn't be supported properly. If the taper was continuos then any sideways movement in the pin or clapper could cause the clapper to jam on the shaft ; it may be that I am just being naive blush!
          Would it not be better to ream a parallel hole through the box and clapper and fit something like a ground silver steel rod to act as the bearing spindle. This could be secured using screws tapped into the clapper box and fixing against flats on the silver steel rod.
          Just a few random thoughts with no experience wink 2.
          Cheers
          Martin
          Edited By Martin W on 15/09/2012 15:07:26
          #98402
          Clive Hartland
            @clivehartland94829
            I should think a taper pin would not have the needed Tensile strength for a Clapper box pivot and would do as Martin says.
            A ground Sliver steel pin with perhaps two grooves and a circlip at both ends. A floating shaft would be better that a |Taper pin which would need to be secure in one part, but which part?
            I see an oil hole in the Block, I would not oil a Taper pin.
            #98403
            Swarf, Mostly!
              @swarfmostly
              Hi there, Mick and Martin,
              The use of a taper pin as a pivot isn't without precedent – I have here a WW2 RAF morse key that uses one. You do need to confine the position of the moving part but fibre washers aren't bad for that.
              I think I even have some taper pins that might approach the size you specify, Mick. The problem would be finding them!!
              Best regards,
              Swarf, Mostly!
              #98404
              Martin W
                @martinw
                I think that your suggestion of circlips is better than my screws as there is nothing that can shake loose.
                Cheers
                Martin
                #98407
                mick
                  @mick65121
                  Clapper boxes are always pivoted on a taper pin, the bore through the tool slide and clapper box is 1deg included, which will ensure smooth operation without any movement around a parallel pin, which might be transmitted to the work surface via the tool bit.
                  #98412
                  Neil Greenaway
                    @neilgreenaway71611
                    Hi Mick.,
                    I have one at 0.350 x 3.150 if this is any use to you. I am away with work for a few days from tomorrow but you can let me know.
                    colin hawes
                      @colinhawes85982
                      Mick,you are right ,you should use a tapered pin in the clapper box even if you make one yourself. Colin
                      #98417
                      Ady1
                        @ady1
                        Seems to be standard practice, even on the tiny hand powered adepts
                        #98418
                        Clive Hartland
                          @clivehartland94829
                          one lives and learns, a Taper pin it is then.
                          #98419
                          macmarch
                            @macmarch
                            #98420
                            Martin W
                              @martinw
                              Mac
                              Thanks for the link, once the reasoning is given it makes sense to use a taper pin. As Clive says 'one lives and learns' and at nearly 70 I am certainly still learning and enjoying it.
                              Martin
                              #98427
                              Sub Mandrel
                                @submandrel
                                You learn somethinge every day! When you don't, you are dead
                                Ian P
                                  @ianp
                                  I too have learnt something today.
                                  My first thought whan I saw the post was, why would anyone want to use a taper spindle? a conventional parallel spindle looks the obvious solution. Having followed the link I now know that a taper spindle is absolutely normal for a clapper box. I can imagine a variation of the idea using shims to change the axial relationship of the two parts to eliminate the need to have a reamer whan adjustment is required.
                                  I would have though that a clapper box bearing arrangement would not be in the least critical. In use any backlash or play would be taken up the moment the cutter tip hits the job. The clapper box will be pushed back against whatever stop it has, and as long as it hits the same stop every cut, the cutter tip will sit in the same place for every stroke.
                                  My curiosity is aroused now ! if a taper pin in tapered hole makes such a good spindle, why isn't the technique in much more common usage?
                                  Ian
                                  #98457
                                  mick
                                    @mick65121
                                    Hi. Neil.
                                    Thanks for the offer, but your pin wouldn't be locating in the small end of bore.
                                    Regards.
                                    Mick
                                    #98468
                                    Clive Hartland
                                      @clivehartland94829
                                      The Taper principle is used in another form Ian, in Tapered Roller bearings !
                                      There was a tale about the Americans shipping wheeled vehs. across the US on flat cars and they ended up with wheel bearing problems. It came down to the balls 'Brinelling' the ball bearing rings in one place from being tied down and the weight and motion damaged the bearings. A change of bearings to taper rollerbearings apparently cured the problem.
                                      #98484
                                      Ian S C
                                        @iansc
                                        The taper pin in the morse key, I imagine its how the the tension is adjusted. Just gone and got my three keys, and one of them, the one for the NZ built ZC-1 transeaver ( Key W.T. 8 Amp no.2) has a taper pin (think these keys were standard post office equipement), the othe key from a British field telephone has a parallel shaft. The third one is for a no.48 set, and is a completely different design.
                                        Ian S C
                                        #98486
                                        Ian P
                                          @ianp
                                          I was really referring to plain shaft and journal (sleeve) type bearings. Rolling bearings are a completely different animal.
                                          Tapered (and parallel) roller bearings are more resistant to Brinelling than ball type purely because of the larger areas in contact. All types can suffer the same problem though.
                                          Ian
                                          #98506
                                          Ian S C
                                            @iansc
                                            The taper pin in the clapper box is a tight fit in the box sides, and a loose fit in the clapper (use the oil hole each time you use the machine). When the clapper becomes too loose, DON'T tighten the pin, you'll break the box. Ream the box and clapper and fit a new pin, the pin has a nut on the small end, this is just to stop the pin backing out of the hole. Think the most usual size pin is #8, it needs to be turned down at the small end for 1/2" to take a 5/16" thread. The nut should be counter bored, so that it can bare against the side of the box. Assemble with a light whack with a hammer, fit the nut and get shapeing.n Ian S C
                                            #98621
                                            mick
                                              @mick65121
                                              Always happy to instigate a lively discussion, especially if the shaping machine is involved, but back to my original question doe's anyone know of a supplier of said taper pins, where I wouldn't have to buy a couple of hundred.
                                              Cheers.
                                              Mick
                                              #98627
                                              KWIL
                                                @kwil
                                                If they have them in stock, AHC of Camberley Surrey will sell you just 1 (usual disclaimer)
                                                #98676
                                                Ian S C
                                                  @iansc
                                                  Once you have the pin (and unless you have one, a reamer), you will need to turn a 1/2" length on the small end to take a 5/16"/ 8 mm nut, see my previous entry. Ian S C
                                                  #98684
                                                  Neil Greenaway
                                                    @neilgreenaway71611
                                                    Hi Mick,
                                                    I am not so sure I understand you correctly – you require a pin 2.750 long with 0.350 OD at larger end – the few pins I have are this 0.350 OD at the larger end however they are longer hence the smaller end will be smaller than you need, and this can be turned down to a parallel OD and threaded for a retaining nut just as has been described?
                                                      Are all taper pins the same taper angle? Surely not. It seems in the past every opportunity to be different was taken.
