ER32 collets
ER32 collets
Home Forums Workshop Tools and Tooling ER32 collets
  • #537136
    Bo’sun
      @bosun58570
      Good evening all,
      Any thoughts on the minimum clamping length for an ER32 collet? I would like to hold a length of 3mm.
      Will it damage the collet if it's too short?
      I did think of another piece the same size towards the back of the collet, but wasn't sure.
      #20223
      Bo’sun
        @bosun58570
        Minimum clamping length?
        #537141
        Martin Kyte
          @martinkyte99762
          I would say the shortest length was the length of the collet but it depends what you are doing and how tightly you wish to hold the piece.
          regards Martin
          #537142
          old mart
            @oldmart
            A backup would be better than nothing, but everything depends on the diameter held, 3mm would be better than larger and clamping 6mm would be risky.
            #537143
              Quite simply … it won’t clamp properly unless you do put that extra piece at the back
              ER uses a double taper to do ‘parallel’ clamping … leave one end empty, and it doesn’t !!
              Edited By Michael Gilligan on 30/03/2021 18:40:01
              #537170
              old mart
                @oldmart
                You would think that the parallel clamping feature would mean that the collets always had one diameter right through. I have some er25 collets with only half the length at the nominal size.
                #537178
                  Posted by old mart on 30/03/2021 20:45:23:
                  Well, actually … I wouldn’t
                  It’s a parallel clamping action, generated by the tapers and the slots
                  … the internal profile is trivial
                  Nicholas Farr
                    @nicholasfarr14254
                    Hi Bo'sun, my ER32 collection of collets only go down to 6mm, I use one of these ER11 collet chuck gripped in a 16mm collet to do smaller stuff and these collets are about 18mm long, although my 6mm ER32 collet has only 23mm that actually does the gripping. These collet chucks also give me much more room and easier to see where the tool is, when holding small cutters on my mini mill.
                    Here's an example of how much easier I find it using a ER11 collet chuck with a small cutter, on my mini mill, the ER11 is held in my normal collect chuck that is used on this mill.
                    Regards Nick.
                    Edited By Nicholas Farr on 31/03/2021 08:01:03
                    #537201
                    Sandgrounder
                      @sandgrounder
                      Posted by Michael Gilligan on 30/03/2021 21:56:59:
                      I'm not saying you're wrong it's just that I'm also having trouble visualising it, say a 12mm collet is being closed on a short length of 12mm shaft by the tapers, once the collet clamps onto the shaft it can't be closed further and everything stays parallel, both the internal 12mm diameter and the tapers, even clamping on to a 12mm ball would prevent further closing of the collet in its taper, I do realise that the longer length that is in the collet the greater the holding power will be for milling cutters etc.
                      Tony Pratt 1
                        @tonypratt1
                        In theory yes the collet should grip on a short length but in practice the rear portion will continue to collapse & you will get a 'bell mouthed' condition on the collet.
                        Tony
                        #537217
                          As Tony says in practice the back of the collet just collapses. For anyone in doubt you can try this at home.
                          10mm collet, 10mm HSS blank inserted 3mm into collet and just nipped up by hand no spanners, that is a 9.4mm drill sticking out the top which won't enter the back of the collet.
                          Edited By JasonB on 31/03/2021 09:18:36
                          #537218
                          Bo’sun
                            @bosun58570
                            Thanks all,
                            I'll use a back-up piece towards the back of the collet as suggested. Clearly it will increase the clamping pressure and life of the collet.
                            #537229
                              Posted by Sandgrounder on 31/03/2021 08:11:54:
                              I think we may be ‘on different pages’ , John
                              Tony and Jason have addressed your point nicely … but my comment was a specific response to ‘old mart’
                              i.e. The internal shape of the collet’s bore is trivial when understanding the closing action of the collet.
                              …. the ones with stepped bores obviously ‘get away with it’ when there is sufficient length being gripped in the larger bore, but I wouldn’t trust any collet to reliably grip a 3mm insertion length. [which is, I think, what Bo’sun was contemplating] unless the material was less than about 1mm diameter.
                              Edited By Michael Gilligan on 31/03/2021 10:11:27
                              #537238
                              Martin Kyte
                                @martinkyte99762
                                Bang on regarding the comments about the closure of the collet. Until the bore is filled it will collapse in a parallel fashion. However the tapers are of different angles the rear being slower than the front. Intuitively you would think that for a full length bore on a cylindrical workpiece/tool that is longer than the collet that it would hold the back portion tighter than the front for any given closing torque. How the dynamics of optimisation to get an even clamping force on the two halve works is beyond me especially when you consider friction and stiction but the parallel length of the rear cone will make a difference. There is also the issue of releasing the collet. Most of mine seem to wedge in place when released and require the active pull out achieved by unscrewing the nut at which point the collet pops out with a bang. The wedging action can only be on the rear cone as the nut taper is no longer in contact at this point. Maybe a releived portion of the bore at the back helps, I don't know really. I've only just begun to think about it.
                                regards Martin
                                Edited By Martin Kyte on 31/03/2021 11:52:41
                                Edited By Martin Kyte on 31/03/2021 11:53:23
                                #537262
                                old mart
                                  @oldmart
                                  When thinking about clamping a 3mm cutter in an er32 collet, it is unlikely that the shank of the cutter would be as long as the collet.
                                  #537263
                                  Martin Kyte
                                    @martinkyte99762
                                    Posted by old mart on 31/03/2021 16:20:30:
                                    Maybe you should use a more suitable series then.
                                    regards Martin
                                    #537322
                                    Sandgrounder
                                      @sandgrounder
                                      Posted by Michael Gilligan on 31/03/2021 10:03:24:
                                      Sorry about that Michael, I should have read the previous posts more closely.
                                      DC31k
                                        @dc31k
                                        Rego Fix show up to four different possibilities for the internal arrangement of ER collets. See
                                        https://us.rego-fix.com/system/files/docs/2017-09/RFAG_TD_ER_Spannzangen-Masse_EN_0.pdf
