Wiring Pt 4
Drum terminals 4 & 8 not used.
Block terminals 1 & 2 not used, in diagram but use say 1 for earth connection, not shown on diagram. Ensure you have a complete run of green and yellow striped earth wire from mains lead to block to motor casing, securely screwed-up tight. Also ensure that stand and lathe also connected. Beware, if you use cork washers under motor bolts to deaden vibration, you need to earth actual lathe, just in case….
Manual says "N.B. When a push button starter, with or without isolator, is fitted, the supply should be connected to it (or to the isolator), NOT to the terminal block."
Standard recommendation is to use a no-volt isolator for on/off and drum switch for merely reversing the motor.
As I dont have an isolator and just use the 3-pin socket switch, I cannot help with wiring in an isolator.
If you want, I will try to scan and send diagram to you. If the above connections fail to effect a reversal, you need to swap a pair of like wires to the motor, say A1 and A2 or T2 and T3.
If in any doubt obtain assistance of a qualified electrician as I cannot accept any responsibility for the previous posts.
