What Did You Do Today (2016)
Home Forums The Tea Room What Did You Do Today (2016)
Viewing 25 posts - 1,851 through 1,875 (of 2,143 total)
  • #268524
    Martin King 2
      @martinking2
      Got a couple of small tool refurb jobs done today, new replacement steel part for a MONUMENT Plumb Bob:
      and milled a large chunk of bronze into a new wedge for a nice French Coopers Spokeshave.
      Used a new solid carbide 16mm cutter that came in a tool auction lot, what a joy to use! Got 6 of them in one smallbox at the botttom of a crate!
      just distressed it a bit and roughed up the grip surface as metal wedges are more prone to slip than wood.
      Cheers all,
      Martin
      Martin King 2
        @martinking2
        Missed the wedge pic!
        #268527
          Posted by Keith Long on 26/11/2016 15:10:06:
          Neil – sounds as if your about to embark on an exercise of "re-inventing the wheel" All the stuff you need is already available, go on to the Model Boats website and send a pm to Dave Milbourn. Tell him what your trying to do, he'll probably be able to quote you the module numbers that you need off the top of his head – he developed them.
          So called tank steering using multiple motors is quite common in multi screw model boats with separate motors, either used alone or in conjunction with a rudder or rudders.
          Why buy when I can make…? I thought we were all model engineers!
          Ian P
            @ianp
            Posted by Neil Wyatt on 26/11/2016 18:15:53:
            I suppose it depends on what you call 'make'.
            The tank mixers I have used were little more than an 8 pin PIC. You could make a PIC based one yourself but you would not go to the trouble of making the PIC itself (any more than you would cast and extrude your own brass bar).
            I see nothing wrong in using a bought it part for the mixing, its only going to account for a small percentage of the whole project so completly ethical.
            IanP
            PS. I am sure I have seen mixer code posted online although using might take some of the fun out of doing it.
            #268537
            Anonymous
              Steady on there, no need to be insulting; my cheque book is mortally offended!
              #268539
              Anonymous
                The VFD for the high speed spindle is now all wired up and installed on a convenient existng plate on the back of the CNC mill column:
                I just need to make a bracket to clamp the spindle to the nose of the mill and I'll be in business.
                #268544
                  Posted by Ian Phillips on 26/11/2016 19:21:43:
                  IanP
                  I would not sully my workshop with a PIC! It will be AVR based, and therefore greatly superior!
                  Microcontrollers are as much one of my hobbies as model engineering and yes 99% of the fun is in writing the code.
                  Here's the thing itself (the extra roadwheel is about 37 years old, as is the gearbox).
                  More detail and pics here for anyone interested.
                  jaCK Hobson
                    @jackhobson50760
                    Posted by JA on 25/11/2016 19:52:19:
                    Does NOX = Nitrous Oxide?
                    JA
                    It's the speak of the street bruv. NOx, NOS, Nitruz is all the same thing. And you knew it so it is probably more widely understood.
                    Posted by modeng2000 on 25/11/2016 20:05:32:
                    Do you know where to get the butane cylinders from?
                    I'm sure the JasonB thread I found suggested that you can refill the butane by opening the valve and using lighter refill can applied to the nozzle. I haven't tried.
                    Edited By jaCK Hobson on 26/11/2016 22:03:01
                    #268550
                    Grizzly bear
                      @grizzlybear
                      Neil,
                      Visited your pictures.
                      Great pictures, Model railway, tanks and space shots.
                      Regards, Grizzly bear..
                      #268556
                        Thanks GB.
                        #268575
                        modeng2000
                          @modeng2000
                          i must have missed that Jack, thanks.
                          Mick Henshall
                            @mickhenshall99321
                            Er well yesterday actually, I have about 3 million carbon steel lathe tools inherited from my Gramps which have lain unused since 1982 so sorted about a dozen useful looking ones out which will get sharpened and tried out. I usually use hss tools as personally I do not get on with insert and carbide tooling, I understand that carbon steel gives a good finish but needs a bit more care when using them, I have sharpened and tried a couple of boring tools and am pleasd with the results, I am not knocking insert and carbide stuff but I do like the old ways of doing stuff and the time taken in grinding tools is well spent
                            Mick
                            #268594
                            James Alford
                              @jamesalford67616
                              Dragon Surgery.
                              I have been working on this structure for some time; hence the previous interest in propane-compressed air blow torches.
                              I spent ages finishing the front legs and showed my wife who promptly pointed out that one stuck out at an odd angle. Back into the workshop, roll it over and attack it with an angle grinder to amputate and reattach the leg; looked like a scene from some sort of medieval Gothic torture chamber. Once this basic structure is finished, I shall cover it in scales. I chopped off the tail as it was too cumbersome to move with it on. That will be attached later.
                              James
                              #268603
                              Nick_G
                                @nick_g
                                In the workshop with my mate motorbike engine rebuilding.
                                He brought round a part for the turbo outlet that another friend of ours has welded. – I did not know you could do this. ………. Weld stainless to cast iron.! ?
                                Nick
                                #268610
                                  Posted by jaCK Hobson on 26/11/2016 22:00:45:
                                  JA
                                  Posted by modeng2000 on 25/11/2016 20:05:32:.
                                  JA has a point doesn't he? In this case "the speak of the street" is very misleading. It's akin to that TV Programme that told us Wrought Iron is made by hammering Cast Iron.
                                  I don't suppose it matters much if you always buy "NOX" from a reputable source who knows what you're using it for. A very different story if it "fell off the back of a lorry".
                                  duncan webster 1
                                    @duncanwebster1
                                    Posted by Nick_G on 27/11/2016 10:29:17:
                                    Nick
                                    The only time I've come across successful cast iron welding they used nickel rods. I daresay nickel sticks to SS as well.
                                    #268615
                                    jaCK Hobson
                                      @jackhobson50760
                                      Posted by SillyOldDuffer on 27/11/2016 11:22:28:
                                      Yes. Both sides do. According to Wikipedia, NOx is everything but NOS. But I'm sure many people buying squirty cream refills do not know, or need to know, it is N20. I sometimes lean towars "if it is clear in context then just let it go" but othertimes their, there, they're, too, to, two annoys me.
                                      Edited By jaCK Hobson on 27/11/2016 11:45:02
                                      #268619
                                        Posted by jaCK Hobson on 27/11/2016 11:44:45:
                                        +1!
                                        #268620
                                        Nick Wheeler
                                          @nickwheeler
                                          NOS when applied to engine tuning is the name of the company that made N20 popular – Nitrous Oxide Systems. But it's become a catch-all term for the idea, a bit like Hoover for vacuum cleaners.
                                          #268627
                                          Muzzer
                                            @muzzer
                                            In automotive industry, particularly relating to emissions, NOx refers to NO and NO2 which are both undesirable byproducts of combustion. They are acidic and corrosive and form nitrous and nitric acid when dissolved in water. Not something you'd choose to inhale even if you could buy it.
                                            On da street, they are referring to nitrous oxide (aka laughing gas) as the stuff you put into your engine intake to boost output, ideally accompanied by additional fuel.
                                            In da hood, it seems that today's yoof are buying the little metal containers that are sold for frothing cream. They also contain nitrous oxide and said yoof have discovered that inhaling it gives them a sort of legal high. So it's not unusual to find loads of empty containers where they have been partying. If you see a yoof buying dozens of them in a shop, it probably isn't planning to make lots of puffed cream.
                                            #268631
                                            JA
                                              @ja
                                              If you look down an exhaust plume, let's say from a big diesel engine or gas turbine, and there is a hint or more of brown in the gas, that is nitrogen dioxide. Its real nasty is, environmentally, reacting with partially burnt hydrocarbons, again from combustion, in the presence of sunlight to form petrochemical smog.
                                              JA
                                              Edited By JA on 27/11/2016 13:23:21
                                              #268639
                                              Alan Wood 4
                                                @alanwood4
                                                Update on Nelly the Elephant ….. on good advice from one of the subscribers I duly gave her 4 coats of Wickes MDF primer (not sure this is any different to any other primer but whatever).
                                                A few days later I painted the first grey gloss top coat using Wickes Exterior Gloss. As the weather outside was not too brilliant I did the job in the workshop. The paint was oil based but not really smelly.
                                                Woke up next day with an unstable feeling stomach which quickly evolved into a very serious 'trouser clip' session. As management had eaten everything I had in the prior 24 hours I can only put it down to the paint fumes.
                                                Anyone else had similar 'experiences' ?
                                                Alan
                                                #268647
                                                  Surely N20 is just NOx where x=0.5?
                                                  Critical to get your Dragon anatomically correct.
                                                  Nick_G
                                                    @nick_g
                                                    Posted by duncan webster on 27/11/2016 11:36:58:
                                                    Nick
                                                    Hi Duncan, Seems you are totally correct. yes
                                                    Spoke to the welder and the TIG weld filler rods were indeed nickle based.
                                                    Nick
                                                    #268673
                                                    Ed Duffner
                                                      @edduffner79357
                                                      Changed a crank oil seal on my SAAB which was leaking oil ( ~3 litres in 1 month) and as I understand it, crank case pressure also. Had to grind a bit of flat steel to wedge in between the starter ring and casing so I could undo the 27mm AF bolt holding the oil pump pulley on to get at the seal.
                                                      Ed.
