Welding and Pacemakers
Home Forums The Tea Room Welding and Pacemakers
Viewing 25 posts - 1 through 25 (of 32 total)
  • #533033
    colin hawes
      @colinhawes85982
      Having recently been threatened with the prospect of having a pacemaker I am interested in the implications for arc welding; Has anyone had experience of this as I use mine very frequently without a second thought? Will I have to give it up or wear special protection? Colin
      colin hawes
        @colinhawes85982
        Discussion
        #533037
        Jeff Dayman
          @jeffdayman43397
          I suggest asking your surgeon and / device technologist about your specific model of device. Effects from nearby fields vary by device, and in general newer devices are much less susceptible to interference or field effects than older devices.
          That said, it would be better to err on the side of caution if you get a pacemaker, and not use electric welding unless your surgeon and technologist say it is OK to do it.
          #533039
          Speedy Builder5
            @speedybuilder5
            Use the welder to jump start your heart if it stops ? Alternatively what Jeff says.
            #533040
            Clive Foster
              @clivefoster55965
              Google search turns up a fair bit of information. Consensus seems to be:-
              A: It is recommended you avoid using welding currents above 160 amps. Follow the safety precautions below to minimize the risk of interfering with your heart device while welding with currents under 160 amps.
              Welding Safety Precautions
              Limit welding to currents less than 160 amps
              Work in a dry area with dry gloves and shoes
              Maintain a 2-foot (60 centimeter) distance between the welding arc and heart device
              Keep the welding cables close together and as far away as possible from your heart device.
              Place the welding unit approximately 5 feet from the work area.
              Connect the ground clamp to the metal as close to the point of welding as possible.
              Arrange the work so the handle and rod will not contact the metal being welded if they are accidentally dropped.
              Wait several seconds between attempts when having difficulty starting a weld
              Work in an area that offers firm footing and plenty of room for movement
              Work with an informed person who understands these suggestions
              Immediately stop welding and step away from the area if you start feeling lightheaded, dizzy, or you believe your implantable defibrillator has delivered a shock
              Since welding equipment may temporarily affct the normal operation of your heart device, any decision you make to use this equipment should be made in consultation with your heart doctor. Your doctor can advise you as to the degree of risk these responses pose for your medical condition.
              Aprons or vests will not effectively shield your pacemaker or implantable defibrillator from the electromagnetic energy generated by welding equipment.
              #533044
              pgk pgk
                @pgkpgk17461
                A little gallows humour.
                I had a client who was an undertaker and kindly gave me a bag of 'removed' pacemakers (in the 90's). I hitched them up in turn to my ECG machine – half were dud…
                pgk
                #533045
                Ady1
                  @ady1
                  Sounds to me like you need to give up welding
                  #533050
                  Oily Rag
                    @oilyrag
                    A very good friend (Farmer Hedley) of mine is a prolific welder, see my photo album for some of his Cast Iron electric gluing! However, he has been fitted with a 'smart' pacemaker which connects to the hospital via the 'Tinterweb' every few days and reports back any problems. He attended a consultation with his consultant who informed him that there were some rather surprising 'reports' back from his pacemaker which he needed to get to the bottom of as it looked like they needed to 'tune' his unit.
                    He asked what the problems were and they said on such and such a date they had some 'noise' on his recordings (several dates and times given). He thought about it and told the consultant "Ah, that was me welding the new gates for the local pub", "That date was when I repaired a tractor drawn implement – tricky job that!" and on and on. The consultant looked on in horror, "But your not supposed to be electric welding" Farmer Hedley explained that if he didn't weld he wouldn't eat and that could be just as fateful! He walked out of the consultation with a nice pre used floral print radiologists lead apron!
                    Problem fixed
                    #533052
                    Martin Connelly
                      @martinconnelly55370
                      I have a vague recollection about people with pacemakers being kept away from TIG sets with HF strike.
                      Martin C
                      #533053
                      mark costello 1
                        @markcostello1
                        FIL had a tuneable pacemaker and could not be around any spark ignition, even from a medium size tractor which had the spark plugs 4 or 5' away with a hood and fire wall between Him. His pacemaker also would knock Him off of His feet when it fired. He could feel the shock coming and once in a while had time to set down even in the dirt.It was adjusted many times with no success.
                        #533057
                        noel shelley
                          @noelshelley55608
                          That lead would have much effect on a magnetic field I doubt, but to maintain 2' between the operator and the Arc would be difficult, thats arms length. Noel.
                          #533060
                          Dave Halford
                            @davehalford22513
                            Foil waistcoat, keeps the aliens away too.
                            #533074
                              Colin
                              May I suggest you read this thread: **LINK**
                              https://www.model-engineer.co.uk/forums/postings.asp?th=153645&p=1
                              … and particularly that you look at the Boston document that I linked.
                              This is probably as good as the available guidance gets.
                              P.S. __ I’m on my second pacemaker, and have read quite a lot about them, so please send me a P.M. if you think I can help in any way.
                              #533079
                              Howard Lewis
                                @howardlewis46836
                                The problem would probably be fields from eddy currents, so maybe an earthed shield of chicken wire between operator and the welding set, cables and work might be a solution?
                                Effectively, do the welding from outside a Faraday cage!
                                #533090
                                martin perman 1
                                  @martinperman1
                                  Whhen I served my apprenticeship 50 years ago the company I worked for had three production lines and all had Wild Barfield Induction Heating machines and in the control cabinets they all had Witches Caldrons, there was a 20 foot exclusion zone around each machine for anybody with pacemakers fitted.
                                  Martin P
                                  Edited By martin perman on 10/03/2021 21:21:50
                                  Edited By martin perman on 10/03/2021 21:22:32
                                  #533092
                                  Mike Poole
                                    @mikepoole82104
                                    I was sent to investigate our presshop travelling cranes that had recently been fitted with radio control to save having a driver sat in the cab all day long. It was reported that the cranes were moving by themselves when a rotary arc welder was in use. Despite the radio control using a dual channel system the arc welder generated enough electrical noise to set the interface relays chattering like mad. The crane driver got his job back while the designers went back to the drawing board. I doubt the old arc welders would have come anywhere near meeting current current emission regulations but cranes lifting a 20 ton die to be totally reliable. I would be wary about being in close proximity to a device like an arc welder and certainly seek reliable advice on how tolerant a pacemaker is to electrical noise. All the inverters for our medium frequency spot welding equipment carried a warning label for pacemaker users.
                                    #533093
                                    Howard Lewis
                                      @howardlewis46836
                                      Witches Caldrons?
                                      Mercury Arc Rectifiers?
                                      Thinking of the currents involved in Induction Heating, I could imagine some large electric fields.
                                      When Ford were developing the anti lock braking system on the Escort, there were problems with the system behaving inconsistently and quite dangerously..
                                      Eventually it was traced back to the test route passing beneath some 432 Kv power lines. A step in the circuit board behaved as an impedance, causing stray signals to be generated. The solution was to change the step to a taper, so that stray currents were no longer induced by the field from the high voltage power line when the car passed beneath.
                                      #533095
                                      martin perman 1
                                        @martinperman1
                                        Howard,
                                        Thank you, we always called them that to the point I forgot their correct names. Years ago there used to be a rumour going around that the large transmitting aerials at Daventry were causing cars fitted with the new electronic ignitions to breakdown.
                                        Martin P
                                        Edited By martin perman on 10/03/2021 21:38:44
                                        #533104
                                        Grindstone Cowboy
                                          @grindstonecowboy
                                          I don't know about arc-welders, but my father in law could feel an uncomfortable sensation from his pacemaker each time I pressed a button on my 2.4GHz wireless mini-keyboard used for controlling the TV. The wife made me revert to the normal IR remote for the duration of his visit.
                                          Rob
                                          #533105
                                            Knowing a little about how difficult it is to fully protect electronics from strong EMI, if I had a pacemaker I wouldn't risk arc welding under any circumstances even though fully applying Clive's list would indeed reduce the risk.
                                            Electric arcs are a powerful source of electromagnetic energy, and the resulting near field is potent even though the far field isn't radiated efficiently. Putting a pacemaker within a few feet of an arc welder will severely stress the device's protective circuitry, making accidents likely.
                                            This maker says it's ok to scuba dive down to 200', but specifically identifies arc welders and faulty electric motors as avoid hazards.
                                            Personally I'd rather pop off doing something I enjoyed rather than safely rot slowly away in a home! Could be taking up welding will be a good alternative to taking a Swiss holiday organised by Dignitas. But not yet!
                                            indecision
                                            not done it yet
                                              @notdoneityet
                                              As well as spurious radiation from arc welding, induction heating is also a no-no for people with pacemakers. In addition, one does not wear anything metal if close to an induction heating system. I am wondering if induction hobs give a warning re rings (on fingers) being placed on a (cold) induction hob while switched on? Or are they sufficiently protected from that sort of thing?
                                              #533163
                                              Mike Poole
                                                @mikepoole82104
                                                Posted by Michael Gilligan on 10/03/2021 20:27:28:
                                                Colin
                                                Does two pacemakers mean you are a Timelord Michael?
                                                #533166
                                                  Posted by Mike Poole on 11/03/2021 10:25:39:
                                                  laugh
                                                  Regrettably not, Mike
                                                  The second one [with three wires] was a drop-in replacement for the first [with two wires]
                                                  The two original wires remain, and they “only” had to insert and connect the third.
                                                  Grindstone Cowboy
                                                    @grindstonecowboy
                                                    You'd have to ask the Doctor Who installed them.
                                                    I'll get my coat….
                                                    Rob
                                                    #533213
                                                    colin hawes
                                                      @colinhawes85982
                                                      Michael G, many thanks for your references there seem to be an awful lot of precautions to remember when fitted with a pacemaker. I have been recommended for one and it seems likely to make a huge impact on my restoration and workshop activities. Thank you for inviting me to P.M. you, I may well do that at some time.
                                                      Thanks also to everyone contributing to this discussion. Colin
