Well after being a proud owner of an E-Type jaguar way back in my early 20's. I was in awe when the V12 came out. I hankered after one, but life got in the way & it never happened. Very fortunate for me i may say. The V12 Jaguar was a bit of a nightmare. I actually worked for some time at West Yorkshire foundry in Leeds doing electrical work, where the blocks were cast.
Quite a sight. They were mahasooive. (Very large).
They suffered from overheating at times , usually due to water leaks. They suffered massively with exhaust valve failure, due to burning the seats out. I worked on a few myself. They said if a 50p piece fell over when balanced on the bonnet , it was poorly.
One particular XJS had burst a bottom hose on the M1. This due to the driver not seeing a problem seized the motor. When we stripped it only one piston had seized.
We advised the customer that it was just a simple matter of purchasing a piston & liner from BL. He advised to go ahead & repair it. We went to then Appleyards in Leeds with a small fist of cash to order the parts.
Only to be told that you can only buy 12 pistons & liner kit.
The car was scrapped.
Why am i rambling on you say. Well have a look at the following link. This is the VW attempt at a multi cylinder engine. What a lovely piece of engineering. Anyone with a mechanical & petrolhead leaning like myself will enjoy this video. There is something about a multi cylinder sound that is very pleasing to listen to. Probably why i spent way too much on my present steed. Enjoy.
The VW – W12 engine being made.
Steve.
