Some thoughts having recently received a WM18B with DRO, stand, and (700 lb) wheeled trolley.
A visit to the Warco showroom and subsequent communication was all well handled by friendly staff. I made a couple of changes to the order but they dealt with those well. The pallet was delivered by a helpful chap on the promised day.
Challenge #1 was opening the crate. Warco had lifted the top of the crate off the base but re-attached it using the original nails – life would have been much easier if they'd used screws.
Challenge #2 was assembling the trolley without instructions and only a small diagram to work from – it's easy with hindsight but needed some head scratching.
Challenge #3 was attaching the base to the trolley. It's a general purpose trolley so does not have any provision for bolting the base to it. I improvised using some unused bars from the trolley, but there should really be an adapter or coupling kit specifically for the task – more about the trolley later.
Challenge #4 was getting the mill on the stand single-handed. The mill was was bolted to the bottom of the crate, which had been strapped to a pallet. Unfortunately the pallet was much wider than the crate base and would not fit between the legs of the hired engine crane. Eventually I set-up boards across the top of the crane legs and slid (much crowbar action) the crate base from the pallet to the boards and could then lift the mill with the crane. Slightly scary moments getting the mill high enough but it worked-out. The correct size bolts for the mill-stand attachment are not supplied so I used the smaller bolts that had been used to attach the mill to the crate (why don't they use the correct size?)
Observation #1: the trolley is very poorly designed. It's useful to be able to move the thing around but the feet are attached to plastic arms which flex easily, so the mill wobbles when it should be sat firmly on the floor. It would be so much better to have the fixed feet rigidly attached to the frame and the wheels on a jacking system because a little wobble doesn't matter on the rare times the thing has to be moved. I'm waiting for a response to Warco on my feedback that the thing is not fit for purpose.
Observation #2: the bracket holding the safety guard had broken – it looks very flimsy but they say a failure is unusual. A replacement is in the post.
Observation #3: the on/off and stop switches were loose. Having removed the panel, the on/off switch had been incorrectly attached (and the connections were not tight so one wire fell out) and the stop switch nut hadn't been fully tightened – neither of these had any provision to stop them rotating, such as a keyhole or hot-melt. As a professional engineer it was easy to fix, but it shouldn't have been necessary. Inside the panel it looked like a good DIY assembly, rather than a production unit.
Observation #4: Initially, neither the R8 reducer nor the collet chuck would enter the spindle because the guide pin in the spindle was larger than the slots in the chuck and reducer. The slot in the drilling arbor (that was supplied fitted in the mill) is much wider than the slots in the reducer and chuck.
Observation #5: I'm surprised that Warco haven't corrected the Chinglish in the manuals, especially for the Sino DRO. It wouldn't take very long to do it and would hugely improve the customer experience. Also, the mill manual refers to WM18B on the front page but thereafter has WMD30VB, which gives the game away – I'm surprised they don't want to customise the manual. Has anyone got an understandable version of the SDS2-3MS instructions?
I haven't checked the mechanical accuracy or set-up (partly because I haven't yet educated myself on how to do it – all advice gratefully received) but it's been used for a simple milling job and was enjoyable to use. It would have been used for some drilling if they hadn't sent the wrong chuck (an exchange is in the post).
Edited By Dave Sawdon 1 on 02/11/2020 19:46:28
Edited By Dave Sawdon 1 on 02/11/2020 19:47:36
