Tools I would like to have
Home Forums Workshop Tools and Tooling Tools I would like to have
Viewing 25 posts - 26 through 50 (of 87 total)
  • #262787
    Bob Stevenson
      @bobstevenson13909
      By coincidence Aldi are currently offering a hacksaw with three blades, one of which is specifically for wood and has reciprocating teeth to cut in both directions. Never seen hacksaw blade like that before but I thought what a good idea it was for a metal workshop since there is often a requirement to cut wooden bits a pieces to aid the work etc.
      Martin Cargill
        @martincargill50290
        Regarding the tap wrench thing. Not quite model engineering but I have a Draper T handled wrench that I use for work. Trying to thread an awkward piece one day I removed the T handle and filed six flats onto the end of the body. Now the T handle still fits and works but I also have the option of using a 13mm socket and any of the pieces from my socket sets and it also works with my 13mm flex head ratchet spanner for the really awkward places (with due care not to break taps). I guess the same trick would work with smaller tap wrenches as well – you would just need to work out what size of socket would match the resulting hex.
        There is also the RAF* solution for the same problem – grip the shank of the tap in a vice and hammer a suitable size nut onto the square shank and then use a spanner or socket to turn the tap.
        * RAF = Rough As F**K
        Martin
        Edited By Martin Cargill on 24/10/2016 19:41:30
        #262795
          Is this sort of 'putting-back' tool still available? The advert is from the 1947 Newnes Engineer's Reference Book, where it's made clear that the tool can be used to reclaim both worn and over-machined parts.
          Edited By SillyOldDuffer on 24/10/2016 20:11:40
          #262796
          Martin Cargill
            @martincargill50290
            Wood welding is possible – google Tregarne wood welder !!!!.
            Its a radio frequency device (a sort of hand held microwave) that dries PVA glue rather quickly. Trying to achieve a rather tricky angled joint in a cabinet a few years ago we were using one of these. One of the shop foremen helping us actually suggested using the wood welder without the glue – he really thought it was welding wood!
            Martin
            #262802
            John Baguley
              @johnbaguley78655
              Check out Adam Booth (abom79) on Youtube. He uses 'metallisation' all the time for building up worn shafts. The equipment he uses looks like an oxy acetylene torch which is fed with metal powder that melts in the flame and is sprayed onto the worn metal. Looks quite simple to do and very effective.
              Ady1
                @ady1
                They use that kind of system to make carbide tooling, it's called sintering I believe, but the temperatures can be very high sometimes
                #262809
                John Stevenson 1
                  @johnstevenson1
                  Powder metallurgy has been around years. On paper it looks good but in practice it's rubbish.
                  I get loads of shafts in that have been metal sprayed, some of the time it doesn't stick properly but the main problem is it's a powder and is always a powder all the heat does it bond it and not weld it to the parent metal.
                  If applied to say a large bearing surface on a shaft and there is anything like depth the action of running hammers the new surface out and you get a loose bearing and a dumbell on either side of the bearing.
                  This is a classic example on some stainless pump shafts. Bearing size is 40mm to give an idea of scale.
                  The threads / rings underneath are to give more surface area and grip to the metal spraying but as you can see it doesn't work.
                  Another disadvantage is when this powder is machined off it's highly toxic and you need very good breathing gear, not a simple mask or you will spend two day gasping .
                  Personally I love metal spraying, it earns me some serious coin, making good these cock ups. wink
                  #262810
                  Roderick Jenkins
                    @roderickjenkins93242
                    We once had team that looked at metal spraying beryllium. Unsuccessful, it incorporated a lot of oxide.
                    Rod
                    #262811
                      Posted by John Stevenson on 24/10/2016 21:16:19:
                      I might have guessed it was too good to be true! I do such a lot of "over-machining"…
                        For repairing by weld build-up [albeit on a smaller scale than JS] … I would 'like to have' a machine like that used by Geoffrey Walker: **LINK**
                        http://www.geoffreywalkerclocks.co.uk/microwelding/microwelding.shtml
                        Edit: Just noticed that the link to Lampert, on Geoff's page, is dead … try this:
                        http://www.lampert.info/en/home
                        Edited By Michael Gilligan on 24/10/2016 21:52:08
                        #262820
                        Roderick Jenkins
                          John''s being a little imprecise about powder metallurgy. I bow to his experience of sprayed powders but pressed and sintered powder is a very important technique for the manufacture of components, not least for tungsten carbide tools.
                          Rod
                          #262822
                          julian atkins
                            @julianatkins58923
                            I need a press for pressing off the axles from loco wheels. I have 3 jobs that need such a press. A slotted bed is required.
                            And of course a much better all singing and dancing bigger lathe!
                            Cheers,
                            Julian
                            #262824
                            John Stevenson 1
                              @johnstevenson1
                              Posted by Roderick Jenkins on 24/10/2016 21:49:21:
                              Rod
                              No Rod you are being very correct, I should have said for the repair of parts. Sintering as you say is done at high temperature and pressure. Although powder spraying uses heat it's nothing like the met=lting point of the parent metal and there is no pressure involved at all.
                              Years ago we used to get scrap lorries in from a local company called Stanton Bonna, they use to have large steel works and blast furnaces in the past. At this time they were experimenting with sintered products and one of the products were small gears for Ford. I'm guessing by the size they were motor drive gears for seats, heating systems etc as they were quite small and fine, probably 24 / 30 DP or around that size and 3mm or so thick.
                              They had been pressed in a die and presumably the next stage was heat treat or the heat treat if done whilst pressing hadn't been carried out. You could hold a gear in one hand and flick a tooth off with the finger of the other hand. More than likely that's why they were in a scrap lorry wink
                              #262827
                              Enough!
                                @enough
                                Posted by Michael Walters on 24/10/2016 10:36:09:
                                Any other ideas would be some long handled spanners so i can stop hitting my hand on the side of the mill when i undo the taper on the drawbar of my mill!
                                You can find a 12-point socket to fit the square on the end of the drawbar and use it with either a long bar or a ratchet (which I find easier).
                                #262828
                                Nicholas Farr
                                  @nicholasfarr14254
                                  Hi, Junior hacksaw blades for wood **LINK**
                                  I agree with John about powder spraying metal repair systems to be useless. In a past employment back in the 70's we had a demo by a rep, looked good, machined up well and all seemed sound, but put back into service and it didn't last very long and the gear soon got slung into a box somewhere and forgotten about for years until it was binned during a shop clear out.
                                  Regards Nick.
                                  #262830
                                    Posted by Martin Cargill on 24/10/2016 20:09:36:
                                    Sounds scarily like a microwave with no door! Although the calim it's 27 MH so plays havoc with RC and CB, no doubt
                                    #262835
                                    John Stevenson 1
                                      @johnstevenson1
                                      This is the patented El-Stevo internal putting it back on tool.
                                      It looks suspiciously like a straight knurling wheel mounted on a tapped hole in the wrong end of a boring bar, but it can't be that simple canit ?
                                      Well can it ?
                                      So the shaft that was a wobble fit is now a press fit.
                                      Obviously not suited for every job, this one was actually a staged shot but very hnady where you have a thin walled part that can't stand being sleeved.
                                      #262842
                                      peak4
                                        @peak4
                                        John, re your internal knurling tool; my preferred engine re-builder has a device for putting a fine knurled thread inside cylinder head valve guides, rather than replacing them. It has the dual effect of tightening the fit on your existing valves, and also retaining oil to help prevent future wear.
                                        Re. the 12" wood saw blades, I just use lengths of 3/8" bandsaw blade, cut to length with a hole in each end. They also work a treat in sawing up large section aluminum alloys. The larger teeth don't clog so easily in softer materials.
                                        #262843
                                        Jon Gibbs
                                          @jongibbs59756
                                          Thanks John I have squirreled away that idea for future use
                                          …but when I think about it there is a woodturning analogue for it when you've screwed up a tenon and made it too small. Plunging a skew chisel straight into the tenon several times along its length can throw-up a series of "burrs" that when filled with glue can cover a multitude of sins.
                                          Maybe a pipe cutting wheel, in place of the straight knurl, would do the same job with less stress on lighter lathes?
                                          Jon
                                          Edited By Jon Gibbs on 25/10/2016 05:08:19
                                          #262844
                                          Geoff Theasby
                                            @geofftheasby
                                            I once broke down on the way to work, ultimately traced to the pin on which the carburettor float hinged, having fallen out, therefore the float chamber filled up causing a grossly rich mixture. The pin being actually 'loose' in its mountings, I persuaded it to stay put by squeezing one end of the pin very hard in the jaws of my pliers, causing longitudinal ridges to form, thereby making it a friction fit which lasted for as long as I kept the car.
                                            Geoff
                                            #262850
                                            John Haine
                                              @johnhaine32865
                                              My first car, an original style Fiat 500, once broke down in the rush hour at some traffic lights in Harrow. A retaining pin in the throttle linkage had fallen off. It so happened that I was stopped outside an estate agency so I popped in and scrounged a paper clip from a bemused lady. That got me going again and was never replaced by the "proper" item.
                                              #262851
                                              jaCK Hobson
                                                @jackhobson50760
                                                I'd like a tool for reliably removing seized cross-head self tappers. Can't drill them. A general unsticker would make home motor mechanics much less of a chore.
                                                #262852
                                                Sam Longley 1
                                                  @samlongley1
                                                  Posted by John Haine on 25/10/2016 07:49:48:
                                                  What???
                                                  Surely you did not keep a Fiat
                                                  #262859
                                                  Martin Kyte
                                                    @martinkyte99762
                                                    I thought with FIATs that was the proper item.
                                                    :0)
                                                    Martin
                                                    #262884
                                                    John Haine
                                                      @johnhaine32865
                                                      Had the "proper" item been designed like a paper clip it wouldn't have fallen off in the first place! I only kept the Fiat for less than a year, but it was an education, not least when the crankshaft sprocket driving the camshaft shed all its teeth. This was apparently a standard feature!
