Dear Merrymiller, My Twopence worth as a wood mainly turner.ML8 headbearing are exposed to contamination by wood dust,an abrasive, crud forming ball flattening (bearing that is) contaminant, hence they are specified to operate on the total loss principle with a low viscosity oil SAE 32 which helpfully runs out of the bearing housings carrying with it the aforementioned undesireables.Spare yourself the acedemic agonising,these bearings are massive and operate at nowhere near their design maxima,lubricate them with ATF and top them up when you feel they need it and they will last another 50 yrs. Using grease may well be technically OK, but in this application you run the risk of killing them with retained contaminants.Most important of all do not adjust them too tight,assuming you are not a cyborg, finger and thumb pressure gently applied to the adjustment collar to arrive at a no end float position will be fine, remember its a wood lathe and you hold the tooling in your delicate fingers, its not an uber rigid, CNC, mega speed, carbide muncher. Happy turning, it's addictive
regards Paul
Edited By Paul Barter on 04/07/2013 18:14:45
Edited By Paul Barter on 04/07/2013 18:15:21
