For a tapped hole drill to 10.25mm, (12 – 1.75), probably 10.3mm will be the nearest easily available.
For many other sizes there are charts available from folk like Chronos, The Tap and Die Co., Tracy Tools and possibly the most comprehensive, if you can find a copy, the Model Engineer Data Sheets. (These cover BSW, BSF, UNC, UNF, BA, Metric Coarse, and the Model Engineer 32 and 40 tpi series).
If you find yourself ever needing to screwcut some thread with an oddball pitch , read off the thread depth form one of charts for that pitch and apply it to the one that you are making, even if the diameter does not correspond to that of the thread chart that you have consulted. This is what you would do if cutting a thread to fit onto a lathe mandrel, of say 8 or 12 tpi Whit form.
