T nut slot channel
T nut slot channel
Home Forums General Questions T nut slot channel
  • #408133
    Chris123
      @chris123
      Evening,
      I’m looking for a supplier of t channel that will take a t nut.
      Length needs to be at least 2 meters, although we will need almost 10 meters so machining it ourselves will be a pain!
      The aluminium profile such as Rexroth won’t really be strong enough.
      I’m unable to find anything, thanks.
      Chris123
        @chris123
        #408134
        Bizibilder
          @bizibilder
          Try Unistrut channel – they do various sizes and you may find what you need.
          #408135
          Chris123
            @chris123
            I’ve been told not to use unistrut as it was my first idea!
            Thanks.
            #408140
            Emgee
              @emgee
              Chris, I find it difficult to understand why anyone would object to the use of a product designed for the intended purpose.
              Emgee
              #408146
                Posted by Emgee on 07/05/2019 20:58:42:
                Emgee
                Not knowing the use that Chris proposes, it's difficult to judge … but [to the best of my knowledge] all unistrut is formed from sheet … The dimensional tolerances may not be good enough, and it may not take sufficient localised loading.
                http://www.unistrut.co.uk/index.php?part=p1000
                Edited By Michael Gilligan on 07/05/2019 21:37:54
                #408149
                Mike Poole
                  @mikepoole82104
                  Aluminium sections are available up to at least 100mm square with T slots. A bit more info on what it is for may get a more focused response.
                  #408152
                  Nigel Graham 2
                    @nigelgraham2
                    Unistrut is really an architectural / electrical-installation material, is folded or rolled from sheet as Michael says; and the applications I have seen rely on simple plain square nuts rather than T-nuts. Perfectly good for its intended purposes and could be used elsewhere if suitable, but it's not intended for precision-engineering or holding very heavy concentrated loads.
                    Regarding point-loading, it might be possible to overcome that by using long nut-strips, but this starts to get messy. (I have used this principle for the T-slots on my EW 2.5" lathe's boring-table and vertical slide, making not separate T-nuts but T-strips the lengths of the slots, to spread the load.)
                    Aluminium- alloy T-slotted channel is made, as Mike Poole says. To help search for possible suppliers, it is for such purposes as electronics cabinet assemblies and among what are sometimes called collectively, "transport sections" (for vehicle bodywork). However, Chris123 seems to need it to take quite heavy loads so these might not suit.
                    If all else fails, whatever this is for, the profile might have to be fabricated.
                    One wonders if a fresh look at the design is called for!
                    #408156
                    Jeff Dayman
                      @jeffdayman43397
                      For steel guides carrying heavy loads you may need to consider something like one of the products at the link below. Not cheap though.
                      T nuts are not really intended to hold heavy loads in suspension in any case.
                      Hopper
                        @hopper
                        More info on the application would be helpful if Unistrut wont do the job.
                        #408164
                        Nathan Sharpe
                          @nathansharpe19746
                          It looks like the link provided by MichaelG is for end supported loads given that they show a deflection. In practice, Unistrut provides support for much greater weights, given that you fix to horizontal substrate (ceiling) or vertical substrate (wall), at the correct fixing spacing. In a concrete building (modern Hospital) , I'm happy for suspension of 200mm/8" heating main to be suspended from Unistrut at 1Mtr centre. In reply to postings as to the nut fixing, it is not a tee nut, it is a Cam nut which aligns two slots/grooves to the rail therefore applying both inward and downward pressure as the fixing screw is tightened. Nathan.
                          #408166
                          Dave Halford
                            @davehalford22513
                            When you don't know the design how can you possibly 2nd guess the solution….
                            Perhaps whoever said not unistrut has only just seen the slotted version
                            #408186
                            AdrianR
                              @adrianr18614
                              You can hang heavy loads on unistrut. I used to fit X-Ray machines. It was normal to bolt the slide rails to the unistrut.
                              #408192
                              Mike Poole
                                @mikepoole82104
                                Unistrut is big boys Meccano, a modern car factory uses miles of the stuff in bringing all the services to the machines, double sections are available for heavier applications. The Bosch Rexroth aluminium extrusion system is used by the ton. All sorts of jigs, conveyors, handover stations and guarding are made from it, available up to 160mm x 300mm sections apparently.
                                #408305
                                Chris123
                                  @chris123
                                  Hi, thanks for the replies.
                                  Must for use in plastic extrusion, for holding a jig into a table. It needs to be quite strongly fixed down so it doesn’t move. Location accuracy doesn’t matter as the table is moved my motors.
                                  We have loads of unistrut, but don’t want to use it. Other machines use this t slot channel but we don’t know where to buy it!
                                  Thanks.
                                  #408313
                                    Chris123
                                      @chris123
                                      Sort of, but much much stronger.
                                      Imagine an aluminium bar 80mm x 80mm x several meters long, with a slot to take a M12 t nut.
                                      #408317
                                      Nathan Sharpe
                                        @nathansharpe19746
                                        I suggest you go to the "8020inc" store on ebay to find your extrusion and then look closer to home. Nathan.
                                        #408318
                                        Ian P
                                          @ianp
                                          I am imagining a long length of aluminium bar 80mm square but if the T slot is in one face only it must be an unusual product or custom made.
                                          Ian P
                                          #408319
                                          Pete.
                                            @pete-2
                                            Posted by Chris123 on 08/05/2019 21:54:27:
                                            Thanks.
                                            So you know what you want exists, you have some, maybe a photo would help people know exactly what you want?
                                            #408376
                                            Chris Gunn
                                              @chrisgunn36534
                                              Chris, in my working life I used "Halfen" steel channel, this is about 50mm wide, 30mm high and will take tee nuts up to 12mm thread. this is much stronger than the rolled steel channels. I believe other sizes are available.
                                              Chris Gunn
                                              #408483
                                              Chris123
                                                @chris123
                                                #408484
                                                Chris123
                                                  @chris123
                                                  Hopefully the picture works.
                                                  For whatever reason we are not using the t nut on this but have bolted straight into the profile.
                                                  #408976
                                                  Hacksaw
                                                    @hacksaw
                                                    Ahh. Probably not what you're looking for,but ..
                                                    I was standing under a 30mph road sign last night, and looking up at it .. on the back face is an ally extrusion , with T nuts holding it to the post ..
                                                    And I thought of this thread !! smiley
