Sulphuric acid
Sulphuric acid
Home Forums Beginners questions Sulphuric acid
Viewing 3 posts - 76 through 78 (of 78 total)
  • #210007
    Vic
      @vic
      Posted by Boiler Bri on 30/10/2015 20:13:02:
      What are you wanting to use if for Vic?
      As before, just cleaning the trap etc. I do once in a while use it for cleaning steel etc but not very often. Just wondered if there was a cheaper source than B&Q.
        The usual confusion when a 3-year's dead thread is resurrected; it had become a long discussion of military issues.
        For now, please keep it back on the original subject of sulphuric acid..
        Bazyle
          @bazyle
          For descaling a drain you could use the more common HCl in the form of brick/patio cleaner wheich can also be used for de-rusting (see other threads as it has been well covered). If you are in a hard water area and occasionally de-scale the kettle you can re-use that as it is going down the drain anyway, just tends to be more benign.
