Good evening,
I use a Unimat SL lathe for my hobby of repairing longcase clocks. I accept and embrace the fact that it is very small lathe but it is ideally suited for my purposes.
The only complaint I have is the 0.8mm thread pitch on the long travel screw. When working on 150mm pieces it gets very tedious.
I am motorizing this with a stepper motor and have purchased a NEMA 17 motor, DM542 driver and FTVOGUE controller with stop/start, direction and speed control.
Everything is fitted and works fine, the motor drives the long travel carriage as desired but there is a problem.
When I press stop, the red alarm light on the driver comes on. It's a constant on while ever the motor is stopped. This driver can report three alarm conditions but none of them are a constant on.
I cannot find anything on the internet to explain this. The voltages from the controller to the driver are all within limits, switching between 0.5v and 4.5v as instructed.
Could this simply be that pressing the stop button, which is actually the Enable/Disable function, disables the driver hence putting it into an alarm condition.
Any suggestions will be greatly appreciated. My electrical knowledge doesn't extend much beyond the Red to Red, Black to Black, Blue to bits level.
kindest regards,
David
